thermosat housings - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-02-2010, 06:53 PM
stoney 81ta's Avatar
thermosat housings
What years and vehicles thermosat housings are compatible with a 1981 305 engine.Thanks all in advance.
Old 07-02-2010, 07:10 PM
poncho62's Avatar
Wiki Edits: 5
Most Chevy thermostat housings exit toward the drivers side where the top rad hose goes into the rad, yours included, I am sure.........Some went straight up toward the centre, but those are less common.......
Some of the housings had spots for emissions fittings
Old 07-02-2010, 07:29 PM
tks Poncho,mine is just the upper hose to the housing,fitting on a performer intake all 350 or 305 with one inlet should be the same?
Old 07-02-2010, 11:46 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
There are dozens of different types (cast, billet, O-ringed, chromed, anodized), different materials (steel, aluminum, zinc), they're made with different angles (90 degree, 45 degree, 15 degree, straight up, adjustable, to name a few).
If you go to Summit you can take a look at what they have and go from there.
I will say the cast chromed zinc necks w/the O-ring are the crappiest things going- they leak and will corrode in no time. Any OEM neck is good, a steel neck is also good. Aluminum is better than zinc IMO, but the chromed zinc are the worst.
I always use a gasket, not just RTV. Be sure to use anti seize on the threads, and use a thermostat.
Old 07-03-2010, 07:42 AM
Thanks for the advice,as for the chrome ones they are crap thats what i have now.
How to take apart crimped gauge housings? fiscus General Rodding Tech 3 11-03-2007 08:36 AM
Wet sanding headlight housings? 37year old kid General Rodding Tech 8 01-07-2007 05:35 PM
Do they have cast iron 9" housings?? 84Z Transmission - Rearend 2 09-04-2005 10:55 PM
taillight housings 68goat Body - Exterior 1 12-21-2004 07:01 PM
cheap ford 9 inch housings for chevys tyson Transmission - Rearend 25 08-11-2003 03:17 PM
