Thermostat - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-27-2013, 06:22 PM
Bobs36ford's Avatar
Last journal entry: Video of new upholstery
Thermostat
HI
Is it really mandatory to install a radiator thermostat. My 350 Chevy engine runs perfect with out one. It runs about 180 in winter and 190 summer.
Bob
Old 05-27-2013, 07:56 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Why don't people use the search function here, up at the top??? Search thermostat, over heating, etc., you'll find tons of information.
Here's a recent example, and there is a thread posted right before it was posted.
sbc cooling issues
Semper Fi
Old 05-27-2013, 11:24 PM
old school sbc's seem to love 180 degree thermostats
helps with warm up and can actually help prevent overheating because water stays in the radiator longer thus staying cooler
The Following User Says Thank You to xzero117 For This Useful Post:
Bobs36ford (05-28-2013)
Old 05-28-2013, 10:45 AM
Irelands child's Avatar
A thermostat provides a couple of functions. First, it allows the engine to warm up quickly and evenly. Second, it provides a slight restriction which forces coolant to actually slow down a slight amount, forcing it to fully distribute through the block, eliminating hot/cool spots. You can be rest assured that if a manufacturer could eliminate that vital component he would, saving a few bucks per vehicle for that profit line. Use a 180* and you should be fine.
Irelands child
Old 05-28-2013, 11:13 AM
Banned
slowing down the coolant CAUSES hot/cold spots.
The singular purpose of a thermostat is to ensure the engine is running HOT enough. If it is not then you will see increased wear and oil contamination.
Old 05-28-2013, 12:40 PM
Where did you learn your thermodynamics?
Irelands child
Old 05-28-2013, 12:56 PM
Banned
University of Missouri- Rolla.
Old 05-28-2013, 01:04 PM
Then they were wrong when it came to heat transfer and fluid motion
Irelands child
Old 05-28-2013, 01:10 PM
Banned
Okay buddy.
I suggest you do a little reading about normalizing closed loop cooling systems, it's really not rocket science but maybe its the simplicity that is too hard for you to grasp.
thermostat 80PontiacWagon Transmission - Rearend 12 01-21-2011 01:24 AM
What are the advantages of running a 180* thermostat vs a 195* thermostat? batman09 Engine 7 01-09-2011 12:19 AM
thermostat, which one? dman0712 Hotrodding Basics 13 11-20-2010 12:07 PM
Do you NEED a thermostat? voodoosurfer Engine 46 11-18-2005 11:03 AM
new thermostat astrops Engine 2 05-13-2004 09:48 PM
