Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Thermostat
Thread: Thermostat
Old 08-14-2005, 06:13 AM
Deuce Deuce is offline
Yes.......the oil is most likely 40 to 50 degrees warmer than the engine coolant. Not a problem.....oil needs to be in that range to properly lubricate the engine. It also helps eliminate condensation from the oil.
WHY are you concerned ?
