Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Thermostat
Thread: Thermostat
Old 08-20-2005, 12:49 PM
xntrik's Avatar
xntrik xntrik is offline
Save a horse, Ride a Cowboy.
Originally Posted by black66
I was running a 160 thermostat for the summer. But on cool nights it would run in the 170's. I bumped up to the a 180 thermostat to make sure the oil would have efficient heat to burn off condensation and sludge......
Thanks.....
ALWAYS run at least a 180 (or a 195) unless you must have the last 3 horsepower possible.. Anything cooler will wear the heck out of your engine. If you worry about the oil temp. use synthetic Mobil 1 oil or Amsoil. You can't hurt them.
Higher temps and better oil will get you more MPG too..... if that makes a difference.
