-   -   Thermostat (http://www.hotrodders.com/forum/thermostat-68088.html)
black66 08-13-2005 11:16 PM
Thermostat
If I am running a 180 thermostat. Most likely the engine oil is hotter than 180????
Deuce 08-14-2005 05:13 AM
:D
Yes.......the oil is most likely 40 to 50 degrees warmer than the engine coolant. Not a problem.....oil needs to be in that range to properly lubricate the engine. It also helps eliminate condensation from the oil.
WHY are you concerned ?
:D
black66 08-14-2005 04:21 PM
Themostat
I was running a 160 thermostat for the summer. But on cool nights it would run in the 170's. I bumped up to the a 180 thermostat to make sure the oil would have efficient heat to burn off condensation and sludge......
Thanks.....
xntrik 08-20-2005 11:49 AM
Thanks.....
ALWAYS run at least a 180 (or a 195) unless you must have the last 3 horsepower possible.. Anything cooler will wear the heck out of your engine. If you worry about the oil temp. use synthetic Mobil 1 oil or Amsoil. You can't hurt them.
Higher temps and better oil will get you more MPG too..... if that makes a difference.
