Thermostat - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-13-2005, 11:16 PM
black66's Avatar
www.airriderz.com
Thermostat
If I am running a 180 thermostat. Most likely the engine oil is hotter than 180????
Old 08-14-2005, 05:13 AM
Yes.......the oil is most likely 40 to 50 degrees warmer than the engine coolant. Not a problem.....oil needs to be in that range to properly lubricate the engine. It also helps eliminate condensation from the oil.
WHY are you concerned ?
Old 08-14-2005, 04:21 PM
black66's Avatar
www.airriderz.com
Themostat
I was running a 160 thermostat for the summer. But on cool nights it would run in the 170's. I bumped up to the a 180 thermostat to make sure the oil would have efficient heat to burn off condensation and sludge......
Thanks.....
Old 08-20-2005, 11:49 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Thanks.....
ALWAYS run at least a 180 (or a 195) unless you must have the last 3 horsepower possible.. Anything cooler will wear the heck out of your engine. If you worry about the oil temp. use synthetic Mobil 1 oil or Amsoil. You can't hurt them.
Higher temps and better oil will get you more MPG too..... if that makes a difference.
Whats the correct temperature my 350 should be running at? batman09 Engine 101 10-23-2005 12:29 PM
Adjustable Fan Thermostat Working in Reverse JohnTN Electrical 2 04-08-2005 11:43 AM
Electric fan thermostat Novaman78 Engine 4 01-27-2005 01:32 AM
Thermostat questions flyfisher Engine 5 09-29-2004 01:21 PM
thermostat crshrmn3 Engine 7 10-01-2003 06:27 PM
