Thermostat bypass on Vortec conversion - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-04-2012, 11:02 AM
Thats what I was afraid of. Do you think if I put on a clutch fan with a shroud it would be sufficient? Although I only have 4 3/4" from the water pump pulley surface to the radiator. I am not sure I can get a fan short enough with the clutch.
  #17 (permalink)
Old 09-04-2012, 11:12 AM
I doubt that would work, the problem is one of areas (tube to fin contact and fin to air) If it won't cool with 60-70 mph air flow through the core from the vehicle's motion, it is not likely that any fan that fits the available space can do as well let alone better.
What is the vehicle? I get the feeling we're talking a older design with a vertical flow radiator. These can be a problem where space for the cooling system is concerned. These older machines had trouble keeping the 100 horse power engines of their day cool. Admittedly we have a lot more Rocket Science available, but it still is not easy to provide adaquate cooling within the available space.
Bogie
  #18 (permalink)
Old 09-04-2012, 11:19 AM
It is a 56 Chevy Truck with a new aluminum cross flow rad (I did not put it in) pic attached (I hope)
  #19 (permalink)
Old 09-04-2012, 01:00 PM
I should re-phrase that. I installed it as it is now, but the rad came with the truck.
  #20 (permalink)
Old 09-04-2012, 01:44 PM
The surface difference between what you've got and what is needed is 36 percent. That's a lot; there are no tricks to overcome this it's just too big a number for fans and water wetter to overcome. I see the paint is probably custom and the opening in the truck's radiator support frame is probably too small so cutting that frame and touching up the paint is sure to be difficult, but I really don't see much in viable options.
However, over the years I done some tricky things where space in hot rods of the 1920's and 30's just didn't offer sufficient radiator space behind the grill without ruining the lines and or finishes. Some of these include:
- Installing a large as practical oil cooler with a thermostat. A lot of load can be taken off the radiator by cooling the oil. But the oil cooler installation needs to include a by-passing thermostat because you need to get the oil temp up but then maintain it. If it's too low the oil can't eliminate trapped water (a component of blow by) which reduces its and the engine's components life span. This can take 10-15 degrees off the coolant temp.
- Using hidden secondary cooling. Capture the coolant from the radiator before it goes back to the pump and run it through a looping length of 1-1/2 inch copper pipe clamped to the frame. You can have a well equipped plumbing or radiator shop roll a bead on the ends where the hoses will attach. Rubber hose adapters see WYSCO from your browser can adapt the 1-3/4 Chevy pump feed side hose to the 1-5/8ths of the tube/pipe. This adds volume capacity to the coolant and uses the contact point to the frame as a heat sink. This method keeps the thermostat and bypass intact and functional. You can tap a secondary radiator into the bypass but this leads into a remote thermostat housing which gets complicated and not very visually pleasing.
  #21 (permalink)
Old 09-04-2012, 02:07 PM
All very good ideas. My first choice would be to install a larger radiator. However I may be limited with the frontal area of the truck and the surrounding components. I will look closely at this first. Of course I would then need to install a new arrangement with the fan(s) and shroud also. The looping length of tubing may work too. Thanks a lot for the reply!
Vortec head conversion - EGR chevy_c10 Engine 10 03-29-2009 11:20 AM
carb/fuel injected intake to vortec tb conversion plate 383silverado Engine 5 09-09-2007 10:36 AM
Water pump bypass, vortec heads blndweasel Engine 2 06-17-2005 05:10 PM
NEW GMPP VORTEC heads !! terror385 Engine 1 07-11-2004 09:48 AM
Hotrodders Knowledge Cluster: Disc Brake Conversions Jon Suspension - Brakes - Steering 0 08-29-2003 03:34 PM
