thermostat question - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2010, 10:37 AM
mitmaks's Avatar
Last journal entry: Grille
thermostat question
This oil heater I have quit working and I'm trying to fix it. Took it apart and there's not much to it. Just switch, thermostat and oil tank. I think that thermostat might be bad. This is thermostat
http://www.smallappliance.com/produc...6&shopBy=Brand
I'm checking it with multimeter and when I adjust thermostat to the left or right reading doesn't change. Does this mean thermostat is bad?
Old 10-17-2010, 12:32 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
What type of "oil" heater is it?
Some electric "oil" heaters have a tank.
Oil fired heaters (oil burners) have an oil tank.
The thermostat in the link you posted is for an electric heater not an oil burner.
What meter scale are you using to test the thermostat?
Using the OHMS scale you will measure continuity across the 2 wires attached to the thermostat. The thermostat must be disconnected for this measurement.
when the thermostat (switch) closes the meter will indicate 0 ohms. When the switch opens the meter will indicate infinity.
You should also hear it click when you rotate the shaft past room temperature.
vicrod
Old 10-17-2010, 01:09 PM
mitmaks's Avatar
This is the heater I have
http://www.amazon.com/DeLonghi-EW050.../dp/B0000DK2YK
There's range on thermostat 0-6. When at 0 it's off and then 1-6 it's on but reading doesn't change. I did take thermostat out to measure this.
Old 10-17-2010, 02:00 PM
vicrod's Avatar
life is a ride
It may not be possible to test the thermostat at room temperature. It will depend on what temperature the thermostat is measuring such as the oil temperature.
If possible connect the 2 wires together from the heater that were connected to the thermostat then plug in it in. If the heater works the thermostat is bad.
This is only a test as it is unsafe to operate the heater without the thermostat.
Don't get zapped..
vicrod
Old 10-17-2010, 02:12 PM
mitmaks's Avatar
Not sure what was wrong but it works now.
383 stroker 73monte Engine 13 05-11-2016 11:17 AM
350 chevy small block over heating? xxxtonyrusxxx@yahoo. Engine 37 09-27-2011 06:10 PM
supercharger.... 73monte Engine 16 07-24-2010 10:27 AM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 01:20 PM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 10:25 AM
