Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Thermostat removal
Old 11-02-2012, 05:57 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by Bobs36ford View Post
Hi
I've had so much trouble with my 36 Ford over heating that i removed the thermostat and it runs perfect now. My engine is a 350 Chevy crate. Since i removed it (now that winter is here) the temperature runs about 140 degrees.
My question ......is it OK to run at 140 VS the usual 190 degree
Bob
Actually the engine will last longer and run just as well at 190 degree F than it will at 140 degrees F, which is way too cool, especially at this time of the year (it will be colder soon).
This is because if the engine coolant doesn't get hot enough the engine will never rid itself of the moisture that condenses inside the engine. This moisture combines w/the motor oil and w/byproducts of combustion to form sludge and will become acidic enough to even damage bearings if left uncorrected.
The Following User Says Thank You to cobalt327 For This Useful Post:
Bobs36ford (11-03-2012)
