-   -   Thermostat removal (http://www.hotrodders.com/forum/thermostat-removal-225655.html)
Bobs36ford 11-02-2012 12:16 PM
Thermostat removal
Hi
I've had so much trouble with my 36 Ford over heating that i removed the thermostat and it runs perfect now. My engine is a 350 Chevy crate. Since i removed it (now that winter is here) the temperature runs about 140 degrees.
My question ......is it OK to run at 140 VS the usual 190 degree
Bob
Adam65 11-02-2012 12:23 PM
No. Put a thermostat back in.
vinniekq2 11-02-2012 12:50 PM
you can use a restrictor instead of a thermostat
joe_padavano 11-02-2012 01:05 PM
Don't suppose you tested the old thermostat when you pulled it out, did you? Most likely the t-stat was bad, thus the overheating problem. Get a new, quality t-stat. I've had brand new Chinesium t-stats that were bad out of the box.
cdminter59 11-02-2012 02:39 PM
Thermostat removal
Here is a good thermostat to use. EMP Stewart High Performance Thermostats 301 - SummitRacing.com. Here is another by Mr. Gasket Mr. Gasket High Performance Thermostats 4364 - SummitRacing.com
cobalt327 11-02-2012 05:57 PM
Originally Posted by Bobs36ford (Post 1606223)
Hi
Bob
Actually the engine will last longer and run just as well at 190 degree F than it will at 140 degrees F, which is way too cool, especially at this time of the year (it will be colder soon).
This is because if the engine coolant doesn't get hot enough the engine will never rid itself of the moisture that condenses inside the engine. This moisture combines w/the motor oil and w/byproducts of combustion to form sludge and will become acidic enough to even damage bearings if left uncorrected.
