Thermostat removal - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-02-2012, 01:16 PM
Bobs36ford's Avatar
Last journal entry: Video of new upholstery
Thermostat removal
Hi
I've had so much trouble with my 36 Ford over heating that i removed the thermostat and it runs perfect now. My engine is a 350 Chevy crate. Since i removed it (now that winter is here) the temperature runs about 140 degrees.
My question ......is it OK to run at 140 VS the usual 190 degree
Bob
Old 11-02-2012, 01:23 PM
No. Put a thermostat back in.
The Following User Says Thank You to Adam65 For This Useful Post:
Bobs36ford (11-03-2012)
Old 11-02-2012, 01:50 PM
vinniekq2's Avatar
you can use a restrictor instead of a thermostat
The Following User Says Thank You to vinniekq2 For This Useful Post:
Old 11-02-2012, 02:05 PM
Don't suppose you tested the old thermostat when you pulled it out, did you? Most likely the t-stat was bad, thus the overheating problem. Get a new, quality t-stat. I've had brand new Chinesium t-stats that were bad out of the box.
The Following User Says Thank You to joe_padavano For This Useful Post:
Old 11-02-2012, 03:39 PM
Thermostat removal
Here is a good thermostat to use. EMP Stewart High Performance Thermostats 301 - SummitRacing.com. Here is another by Mr. Gasket Mr. Gasket High Performance Thermostats 4364 - SummitRacing.com
The Following User Says Thank You to cdminter59 For This Useful Post:
Old 11-02-2012, 06:57 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by Bobs36ford View Post
Hi
Bob
Actually the engine will last longer and run just as well at 190 degree F than it will at 140 degrees F, which is way too cool, especially at this time of the year (it will be colder soon).
This is because if the engine coolant doesn't get hot enough the engine will never rid itself of the moisture that condenses inside the engine. This moisture combines w/the motor oil and w/byproducts of combustion to form sludge and will become acidic enough to even damage bearings if left uncorrected.
The Following User Says Thank You to cobalt327 For This Useful Post:
What are the advantages of running a 180* thermostat vs a 195* thermostat? batman09 Engine 7 01-09-2011 12:19 AM
Thermostat or Not?? S10 Racer Engine 3 03-05-2009 11:28 PM
Trim Clip Removal, and backseat removal? ROBINGOODTIME Body - Exterior 2 10-09-2006 09:15 PM
new thermostat astrops Engine 2 05-13-2004 09:48 PM
No Thermostat? GearHead69 Engine 12 10-06-2003 09:15 AM
