Thermostat on wrong end - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-19-2013, 09:16 PM
Last journal entry: Just odds and end pics
If I would tap and thread the heads at the bell housing area and use a remote thermostat housing there what would happen to the temp [hot spots]of the enigne if any. I know I would have to do some thing at the front to get air out because of the tilt of the engine?
Old 01-19-2013, 09:34 PM
hcompton's Avatar
Old & Furious
A simple tapped screw with a seal will allow bleed from multiple points if need be.
But not sure why you would want something like that. The water inside the head may be at an uneven temp on that part of the head. If you have a hot spot you may just want to run tje heatwr line out of that area and back to the pump that will pull fresh water into the hot area.
You may need to machine the head with a small lip for the thermostat seal. Also two thermostats do not work. But you can use several small orifices and run and open system. Keeps fluid moving across all surfaces if done right but usally getting the water in the raditator cold enough is all that is needed. Unless this is a mid engine build up. Big alum rad and good pump should sort it out.
Old 01-20-2013, 07:37 PM
I'm building a gasser type car like dad ran but would be a street/strip use car to take to shows. Was looking at putting radaitor in trunk with electric fans ,55 GPM electric remote water pump. Was thinking of running a 5/8 or 3/4 line out of the rear of each head to a remote thermostat housing like the ones on blower intake. This is to just hide as many lines as possible. Still going to put water into the engine up front, but have been told that I could go into the center of the block on both sides also like some sprint cars are set up. Will be running small block chevy with a 6-71 blower.
Old 01-21-2013, 04:37 AM
Most engines circulate coolant from front to back in the block then from back to front in the heads. Your plan runs the risk of overheating the front of the heads.
What's wrong with this 10 bolt rear end? Caliper orientation Riot Racing Transmission - Rearend 9 09-21-2011 09:12 AM
Rear End Ratio - measured and number looks way too low - what am I doing wrong? ggevaert Transmission - Rearend 6 07-27-2011 07:37 PM
What are the advantages of running a 180* thermostat vs a 195* thermostat? batman09 Engine 7 01-08-2011 11:19 PM
No Thermostat? GearHead69 Engine 12 10-06-2003 08:15 AM
thermostat crshrmn3 Engine 7 10-01-2003 06:27 PM
