Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Thermostatic Air Cleaners & Smog
Old 03-25-2013, 04:58 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by Dizturbed One View Post
Busy weekend, but I'm back to it now.
I don't think my truck has the right air cleaner on it. In the current configuration it wouldn't be able to run a foil tube from the air cleaner to the heat shield very easily. Everthing else looks to be in place and working, although I am going to go through it meticulously once I get this air cleaner figured out and working, it seems to be my only "missing" equipment
I was going to bite the bullet and simply buy a new replacement, figuring it would be a pretty common design into the 80's... But no. So I will make this one work. Anyone know of a bolt on fix by any chance? I am in apartments, and quite limited on what I can do.
I was thinking of looking for a bolt on heat shield riser (basically a heat shield that is made to fit the foil tube) that I've seen on many older vehicles, but can't remember what kind of vehicles had them. Hopefully many vehicles with 350's had them, and hopefully they should fit on my exhaust manifolds (400 cid), correct?
On another note, found out it is missing two intake bolts
Getting on that one while I chew on the air cleaner situation, any ideas are greatly appreciated
If the exh. manifold has a tin heat shield already on it, you can pop rivet a can to it to hook the foil tubing to. If done right you should be able to make it look convincing, even though it wouldn't be operational w/o the temp sensor(s) that mount to the filter housing (they route vacuum to the flapper vacuum motor at the appropriate time).
Because of how the smog test is done, that shouldn't effect the outcome as long as the flapper is in the open position and the engine fully warmed up.
But if there's no heat shield to mount anything on, you'll need to use something like the hot air choke kits, except on a larger scale. And I don't know of any kits made for the ThermAC setup, either.
