Thermostats - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2013, 12:02 PM
64Joker's Avatar
64Joker
Thermostats
Just curious, besides allowing the engine cooling flow to start from the engine through the radiator, what other differences, if any, would there be in running a 165 degree thermostat versus a 185 thermostat?
Engine: 327 cui
Tran: 350 Auto
HEI
Old 04-22-2013, 01:25 PM
Engine: 327 cui
Tran: 350 Auto
HEI
Why lower the temperature to 165?
Yes, the thermostat opens at 165 instead of 185. Other than that all that happens is wear goes up, the oil keeps more water in solution, acid formation in the oil and sludge formation increases. If this isn't a race only car that sees between race maintenance, this isn't a good idea.
Bogie
The Following 2 Users Say Thank You to oldbogie For This Useful Post:
NEW INTERIORS (04-22-2013), techinspector1 (04-22-2013)
Old 04-22-2013, 03:48 PM
Rick 5150 69's Avatar
Chances are you will start running hotter....
Mr. Gasket Thermostats doctorjohnny Engine 3 12-11-2008 09:07 AM
thermostats sgunlock Engine 13 09-17-2007 04:28 PM
195 / 160 Thermostats - What's the Diff? horvath Engine 34 11-19-2004 05:26 AM
thermostats montea Engine 13 05-15-2004 01:15 PM
Best running temps/thermostats? adryan16 Engine 1 03-08-2003 07:44 AM
