Are these Brodix heads ruined? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-03-2010, 02:49 PM
ags111075's Avatar
My friend has a set of Brodix heads i can get them for $400. I was going to put them on my 400sbc for my tbucket. The guy he got them from said they are stage 7 porting whatever that means. It appears to me that someone overported the intake runners and i'm not sure how the gasket would seal. Here's some pics of them. Thanks in advance Aaron
ID:	49523   Click image for larger version
ID:	49524   Click image for larger version
ID:	49525   Click image for larger version
Old 11-03-2010, 03:03 PM
They're OK, if any leakage occurs it will be port to port which is not a significant problem.
Don't forget to drill for the steam holes if they aren't there already. This insures that hot pockets don't form at the upper cylinder walls and head decks at lower RPMs and power settings when the pump isn't spinning fast enough to blow out the steam if there aren't these passages to vent the pocket.
Bogie
Old 11-03-2010, 03:15 PM
How fast is fast enough?
I'd be more concerned about the exhaust sealing than the intake. I'd save your money $400 is really not a great deal for a used set of those heads. Its a good deal if they are in good usable condition, but it looks like someone leaned on them hard with a grinder (not to be confused with porting).
Old 11-03-2010, 04:04 PM
bigdog7373's Avatar
Of course it's fast
They look alright, but idk if i would buy them. It looks like someone went a little overboard with the porting, or grinding, whatever they did. They should work fine though. It's up to you. 400 isn't very expensive for a set of heads.
Old 11-03-2010, 04:17 PM
BigRoy1978's Avatar
Some people should not be let near a die grinder....
Old 11-03-2010, 04:42 PM
ags111075's Avatar
He sent me some numbers off the heads i went Brodix website the part# 8 std fp ri they were casted back in 1983. Does anyone know what the specs are on these heads?
Old 11-03-2010, 04:46 PM
The specs don't matter much any more, nothing is as it came from brodix. That port looks way too big unless they're running something like a 2.100" intake valve, maybe bigger. Just keep an eye out for some iron eagles or something like that, save the worry and hassle for someone else.
Old 11-03-2010, 04:58 PM
68NovaSS's Avatar
Wiki Edits: 9
I wouldn't want the intake gasket protruding into the port flow area either, I would think about turbulence/reversion at the transition. May not be a major issue, but gives new meaning to the term port matching...
Old 11-04-2010, 07:55 AM
Pass on those heads. Heads that old were not made from the greatest alloy.
You can just cut out the gasket between the common intake runners. It does not really change how it runs if you have a big cam.
How good are pro comp cylinder heads automedics Hotrodding Basics 49 04-22-2013 05:40 PM
Brodix Heads streetrodderbn Engine 7 02-06-2010 04:47 PM
Why spend money on heads? F-1Rodder Engine 8 03-07-2008 12:09 AM
Headers and Brodix Track 1 heads Blue68Camaro Engine 6 09-25-2007 07:40 PM
Heads novatech Engine 10 01-17-2004 01:27 PM
