Are these chevy wheels? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-18-2010, 09:12 PM
I bought an '86 14 bolt axle to put under my '79 half ton. I did not get any wheels with it. I found these wheels at my local used tire place and got some tires to put on them. They fit and will work fine but i'm not sure they are correct. I had many 8 lug wheels to choose from, but i chose these two. They look like Chevy wheels to me. However, you guys look and tell me what you think.
Notice the gap between the wheel and the hub, thats my main concern. Wouldn't the correct wheel fit right up against the hub? Also Notice how you can see the drum sticking out behind the wheels. Is that how it should be? They don't stick out on the stock 12 bolt
ID:	43296   Click image for larger version
ID:	43297   Click image for larger version
ID:	43298   Click image for larger version
Old 01-18-2010, 09:35 PM
n_keiser_rat's Avatar
its homemade, and its cheap!!!
that looks like the ford van wheel because its has the spot where the hub cap clips on. and it looks like to one on my plumbing van its a 98 ford van
Old 01-18-2010, 09:48 PM
Well i've noticed most ford wheels have the ford emblem stamped in them. I saw some of those in the pile of wheels that i got these wheels from and I chose these because they didnt have any brand markings on them. That doesnt mean that these couldnt still be ford wheels tho.
Old 01-18-2010, 11:14 PM
thats a good point mine are stamped and say ford... i dont know then...
Old 01-19-2010, 12:45 AM
ericnova72's Avatar
More for Less Racer
The gap around the hub is normal when using Ford or Chrysler wheels on a GM truck. The Fords and Chryslers have a larger hub hole than GM but the same wheel bolt pattern.
Old 01-19-2010, 06:25 PM
Well I dont think they are ford wheels. So youre saying I probably have DODGE wheels on my chevy? I better be careful those wheels might fall apart. lol!
Chevy steering wheels 41 kustom Suspension - Brakes - Steering 4 09-24-2009 08:06 PM
Chevy steering wheel donor for 39 chevy? Chevy39 Interior 12 07-24-2009 09:00 AM
beware whiteys wheels Dainleljedal06 Off-Topic 7 08-17-2008 06:48 PM
37 chevy fenders vs. wheels bodymanace Hotrodders Site Suggestions and Help 1 10-27-2006 10:29 AM
Questions about wide wheels and fender flares tcruise Body - Exterior 5 06-09-2006 05:50 PM
