These Flexible sanders/long boards - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2006, 12:50 AM
bit bit is offline
that's the car I plan to restore.
Do you think the flexible sanding blocks will be necessary for those curves? I really don't want to spend 200$ to buy these, but I will do so if I have to.
flexible sanders
Old 01-08-2006, 04:28 AM
adtkart@aol.com
I don't see anything on that car to fix! What are you planning on doing to it?
Sanding blocks are made in every different shape and size. I don't personally know of anyone that has all of them. I have a few different shaped ones, but not that many. I mainly use a small 4" soft block, and a "teardrop" shaped one. Alot of guys that I know use a longer, about 12" flat one for larger panels with slight curves in them. The others I usually only use for areas that are hard to get to. Everyone has their own preference. I would not spend $200 for soft blocks for one car.
Aaron
Old 01-08-2006, 06:08 AM
bit bit is offline
that's not exactly my car, the photos are supposed to just give you an idea of how the curves of the car look like.
Old 01-08-2006, 06:47 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
A long flat block will work just fine on surfaces curved
more than that VW. You just have to sand in the right direction,
and take your time. It's an artistic thing, shaping filler and panels,
and there's no substitute for experience. The more you do the better
you will get. You just have to get your time in to be good.
Being patient will help you the most.
Old 01-08-2006, 07:38 AM
bit bit is offline
ok nice to hear so, 200$ for more beers to drink then
Old 01-08-2006, 12:19 PM
jcclark's Avatar
The Penny Pincher
Now you're talking!!!
Plus, after the beer it will always look better.
Old 01-08-2006, 04:41 PM
adtkart@aol.com
Yes... Beer definately helps with body work. If it doesn't look right, you need another one. If someone else comments on it, they either need one, or directions to the door. LOL
Aaron
Flexible sanding blocks Chapo1 Body - Exterior 33 05-30-2012 07:46 PM
flexible sealant mike76 Interior 15 08-11-2005 02:05 PM
what other boards do you recommend? Jon Hotrodders' Lounge 56 06-21-2004 09:02 AM
Surf Boards, Anyone? VonGooch Hotrodders' Lounge 2 01-19-2004 08:34 PM
Running Boards toolmansson Body - Exterior 3 05-08-2002 04:05 PM
