are these header gaskets supposed to be like this??
I'm talking about these: http://www.summitracing.com/parts/PHP-66012/?rtype=10
Are they supposed to have 2 pieces per side? I don't know if it's supposed to be MLS and I'm supposed to stack em' or they accidentally gave me 4... Look at this: ![]() They're only stuck together at one end. All four look the exact same in every way. The heck am I supposed to do with this? |
I have double-gasketed using paper (asbestos? in the old days?) gaskets, but those aluminum ones should be thick enough to do it singley.
I developed a bit of a routine when it came to installing those paper gaskets. 1.) tighten 2.) idle until up to operating temp. 3.) tighten 4.) go for a short drive around the block without getting on it too bad. 5.) tighten 6.) turn it off and allow everthing to cool. 7.) tighten 8.) restart, idle until warm 9.) tighten 10.) take it out on the highway and drive it like you stole it. 11.) tighten Every Sunday Re-tighten. I had this really nice (inexpensive) double box-end wrench (3/8" x 7/16") that I heated up with the torch and hammered more or less flat that snuck right in there. It was about 10" long, so you could get a fair amount of leverage on it. I still have that wrench, come to think of it! |
header gaskets
The ones in the Summitt link are not the same as the pictures. The gaskets you have in the picture are going to last maybe a week before leaking on both ends.
My guess is that they were double-gasketed in an attempt to compensate for warped flanges.
Cheap headers are notorious for having thin flanges, and SBC's have a lot of distance between the center and outside ports, which make those flanges a little more susceptible. Run a straightedge over them and have a look. Get some THICK soft aluminum gaskets. |
header gaskets
As said earlier they sent you 2 sets because they are rejects. Double header gaskets is just twice as prone to leak. I would send them back and get some descent gaskets. There is not enough material on the ends of those gaskets to seal.
| HEADER gaskets! | ONECUSTOM73 | Engine | 8 | 04-19-2010 02:50 PM |
| header gaskets | dwain | Hotrodders' Lounge | 2 | 09-22-2009 10:59 AM |
| the best header gaskets to use????? | dannyessexc | Engine | 8 | 05-15-2009 04:02 PM |
| Header Gaskets | rcm800 | Engine | 12 | 06-11-2007 08:38 PM |
| header gaskets | markzepp820 | Engine | 5 | 12-14-2006 05:42 PM |
