They dont like the heat do they
I've been all over the place showing off how this stroker of mine runs. But today was one of those days that the thermometer at the house was flirting with 100F. I took it out and for the first ten minutes its not great but its OK cause the only thing plaguing it is the sloppy air, but then the 160 degree thermostat lets things get up to 180. Well theres where the fun stops. Sloppy air plus hot engine. Perf goes out the window. My builder is supposed to be getting me a better thermo from hypertech I think he said. Although I got the airgap manifold I wonder if a carb spacer with some heat sink qualities would help? cause that carb got frikin warm. I'm thinking phenolic resin but I heard on hear someone got good results even with plywood. Not that I would run it much in 100 degrees cause I got cars with A/C for that but its nice to know it could get out of its own road on a 100 degree day if it had to
180 is actually better for your engine than 160
Artificial Intelligence is no match for Natural Stupidity Chet |
I've had excellent results from wooden spacers that I made from marine grade plywood. They will insulate the carb very well- aluminum is a great material for conducting heat- I'd avoid it if heat soak or fuel percolation is suspected.
DONT EVERYBODY BLOW A ROD HERE,OK?
I'm trying to figure out why then my builder says and I quote "Ya Doug they'll run better at under 180 but their a 8itch to keep down there, but we'll get you a better than store brand thermo to see if it'll help" and I'll reiterate. Everything I've seen starts to dog off right at 180? You can watch the gauge in the car and as soon as it even gets close to 180 they start a slow power loss and that sickening sound I hate where they go from a brap when you snap the throttle to a real soft kinda zing sound. Not explaining that well but you get the idea |
Easy to keep a 1/4 mile drag engine cool for big power #'s, much harder to do when it has to go more than 1/4 mile, just like your builder has alluded to. Just the engine's water temp at 180° is not the sole criteria for the power loss, hot underhood air is the big power killer. Lowering the engine's water temp is only going to help a little bit, once everything is heated clear through and the headers are hot you will be right back in the same place unless you have some kind of cold air package sealed to the carb.
I guess the other option is riding it when it was intended for. Cool evenings. I'd thought of scooping the hood. Just trying to figure where to get one to fit the 69 impala and whether it would look decent or not. It would be different |
I inherited my Father's /'69 Impala SS 427/390 in '72. Had fiber optic light indicators on the front fenders and rear package tray facing forward that you would see when you looked in the rearview. I guess they all have that, always thought that was goofy, but cool.
Anyway, you might consider the cowl induction scoop for your Impala. |
I've been googling like crazy trying to find the name of the company that made the standard looking breather out of a black material. It was double snorkelled like the magnum series dodge engines in the sixties and to each of those snorkels was a hose that you cut to whatever length you needed and they went to intake boxes at you grill. Anybody know what I mean?
| time for some more heat! what do you think of this heater? | smithkustoms | Garage - Tools | 15 | 02-03-2010 10:45 AM |
| Effects of paint on cooling components | Animal | General Rodding Tech | 7 | 03-12-2006 05:10 PM |
| Heat shrink, routing wires, etc. | Blackdog | Electrical | 4 | 10-16-2005 07:18 AM |
| over heating | delsman | Engine | 38 | 09-14-2005 08:32 PM |
| How are you going to heat your house this winter? | CrashFarmer2 | Hotrodders' Lounge | 29 | 09-05-2005 06:11 PM |
