is thick fiberglass a bad thing? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-12-2012, 09:41 AM
long story short, replaced qtrs in my 70 dart. where i welded them in caused warp. i used short strand fiberglass to strengthen the thin keystone qtrs and fill the warped areas. in one spot (3"x4" area) its 3/4" deep counting the mud on top. whats your opinion on this holding up? thanks
also whats a good way to strengthen thin sheet metal?
Old 11-12-2012, 09:46 AM
NEW INTERIORS's Avatar
Set no limit's on yourself
The short strand bondo holds up well when put on right.. Why didn't you try hammering some of it out ?
Old 11-12-2012, 09:52 AM
actually i did pull it out and finish the work but the longer it sits in the sun the more i could see a dent in that spot, i figure the area is stretched and without shrinking or leaving the dented area i will never get the panel to stay straight. the entire build is done and in paint so trying to fix with out making a huge mess.
Old 11-12-2012, 09:54 AM
I understand..
Old 11-12-2012, 09:57 AM
poncho62's Avatar
Wiki Edits: 5
3/4" is a ton of filler. Personally, I would be redoing the whole thing
Ontario Rodders
Old 11-12-2012, 10:08 AM
Faith - Respect - Trust
3/4 of an inch is rather thick. The thicker the filler or fiberglass the more easily it will not stay on over time, if the car gets tapped near the fiberglass/filler repair. Depending on the product you used the thickness should not be over 1/4 inch and I think that's a bit thick.
I don't know how you welded the quarters on but a safe way is to stitch weld them...one bead at a time allowing the small weld to cool while welding at a spot further away from the original weld. This will minimize warpage.
If the panel does warp, you can use a body hammer to try and straighten the warped area, I prefer, either stretching or shrinking the metal to bring it back to it's original, I could explain but this site will give you all the information and he's already written it out:
Ferguson Coachbuilding
Hope this is what you where looking for
Ray
Old 11-12-2012, 10:12 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Getting that metal shrunk is just part of a collision repair or restoration soooo...remove the thick glass and do it over..you will thank yourself later..
Sam
292 ci six.... Good or Bad Thing? PureC4 Hotrodding Basics 31 03-20-2013 08:39 PM
exrta thick fiberglass fenders 46 ford coupe ritchie buffi Body - Exterior 2 06-22-2007 07:39 PM
Is this a good thing or a bad thing? Rob Keller Off-Topic 4 04-30-2007 09:54 PM
Who Said No Such Thing As Bad Gas 1BAD80 Hotrodders' Lounge 4 11-20-2004 08:04 PM
40 over 350 a bad thing? dpjmw Engine 1 08-29-2004 01:09 AM
