I have that same gaskety on my engine and it fit the same way... however I did have to RTV the corners where the pan rail meets the timing cover / rear main t oget a good seal with it..
the mr gasket 2 piece timing cover was a MISTAKE.. that thing leaked.. so i got a nice heavy steel cover (proform) and cut the tabs at the corners off so i could Remove it without loosening the oil pan.. good to go... -Christopher |
I agree that mr .gasket 2 piece is a 2 piece of junk. The cover is so thin that as soon as you tighten the cover it will start to leak. You have to use about a half tube of silicone to seal it up.
The one piece ones aren't that bad but the two piece ones are nothing but trouble.
I have an Edelbrock two piece and itīs always misting oil.
A new gasket set will cost you $29.95.....
After putting everything back together, my china o ring thermostat housing finally gave, so I put a stock one on, the hose is being "pulled" slightly, but I guess it works for now, while the car is still un-registered/insured. The timing cover is also leaking, not from the oil pan seal, but it appears to be from where the actual "cover" meets the plate that sits against/closest to the block..
| SBC Stroker Oil Pan Problem?? | 89SDime | Engine | 2 | 02-12-2007 03:07 PM |
| Front main seal question | oregon chevelle | Engine | 2 | 07-11-2006 05:17 AM |
| th400 front pump seal question | meev182 | Transmission - Rearend | 6 | 07-01-2006 08:22 AM |
| front seal/ rear main seal...help | mrobby440 | Engine | 2 | 05-11-2006 05:31 PM |
| 302 front sump pan | FAIRLANE DUDE | Engine | 4 | 12-08-2004 10:02 PM |
