thick header gaskets
im looking for any company that sells the thick header gaskets. 1/8 inch thick . i saw a set on a small block chevy but the guy who owned the car said he bought the car that way. no help. any help would be appriciated. e mail at namdlo@fidnet .com
As long as your header flanges are in decent shape, you do not need thick header gaskets. Use Victor-Reinz "Nitroseal" header gaskets, which are available at NAPA, CarQuest and others. These gaskets have graphite facing bonded onto a perforated steel core. The header flange and head surface must be absolutely clean and dry. Do not use any goop or sealers. Tighten the header bolts from center to outside in several steps, just as you would torque head gaskets. Start the engine, let it warm up good and re-tighten the bolts (don't burn your hands!), shut down, let the engine cool completely and retighten bolts again. Check all the bolts and tighten as necessary for the first week or so, then you will have no more header gasket worries.
I got Percy's aluminum gaskets. They are made of lots of thin pieces laminated together. THey are quite thick when uncompressed
I used raised runner alum.angle plug heads on my 69 SB camaro,
Had clearence prob. I called the header co. they sent me a set of chrom flanges1/4 thick,used gaskets on both sides and accell short plugs, I`ts close but it works. HTH; Troy; |
