thin caliper - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-24-2006, 04:36 PM
thin caliper
Hello
I am putting together a set up on the front of my street/strip car. I need to find a caliper that is thin on the outside, since my rotor is close to my rim
I am making a custom inner hub, so I can bring the rim in away from the fender, so I am using a rotor off a Lumina which has a shallow hat. I don't have room for the Lumina caliper and the Weld Wheel rim
Does anyone know of something that may help me out for dimensional purposes? I can machine things a bit if I have to, but if something is readily available it will make it much easier
thanks
Tom
Old 01-25-2006, 01:08 AM
Check out Speedway's website. Hurst/Airheart - now part of the mr gasket empire used to make thin rotors and calipers for spindle mounts in the 70/80s.
G'day Tom, bad bushfires here, check out the CFA website.
Old 01-25-2006, 04:00 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
May or Maybe not
Dunno if this helps or not:http://www.ssapubl.com/index.cfm?do=...&productid=193 this is a blueprint for making your own calipers..If all else fails this may be the way to go..
OMT
Old 01-25-2006, 02:14 PM
caliper
Hello
Thanks Ian and OMT. I ordered the blueprints from Steve Smith and I have contacted a manufactrer for more info on their product
If I cannot buy ones that will fit, then maybe I will make my own
thanks
Tom
Disk brake caliper & steering arm hitting gator412 Suspension - Brakes - Steering 3 05-28-2005 10:31 PM
Caliper hanging causing pull while braking RAW Suspension - Brakes - Steering 4 07-12-2004 10:24 PM
Ford Explorer Brake Caliper Problems Jag Daddy Suspension - Brakes - Steering 4 05-08-2004 12:48 AM
kelsey-hayes 2 pin floating caliper 62galaxiguy Suspension - Brakes - Steering 0 04-16-2004 09:40 AM
Best Ford caliper for 11" rotors on Mus II IFS Darkman270 Suspension - Brakes - Steering 12 03-06-2004 04:20 PM
