Things I should look for on a 47' desoto coupe. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-09-2008, 02:52 PM
chlsnk's Avatar
"Love what you do for a living
I have found locally a 47' desoto coupe and am planning on going to take a look at it some time this week. What should I look for the guy says it turns over the grill glass engine tranny is all there and it is 98% complete only missing the radiator and ashtray .But it is in a barn find condition.
Are these cars very desirable the guy says only 500 of the business coupe models were made that year is this right? What would be a reasonable asking price?
Old 07-09-2008, 03:09 PM
streetrodderbn's Avatar
Certifiable Streetrodder
Any car is only as desirable as the person who wants it! Anytime you look at a rare/off the beaten path car or make, you want the most complete car with all the trim and parts intact as you can get. Don't assume that you can get: patch panels, trim,glass,suspension pieces,...ect. unless you research them in advance, and have reputable sources! The rare cars are the neatest sometimes of any cars, but the headaches finding parts has made many project cars sit abandoned!
Old 07-09-2008, 03:46 PM
Wiki Edits: 49
Unlike Chevys and Fords of that vintage a lot of stuff is not available for the DeSotos. That said, what you need to make sure is there and in decent condition are things like trim pieces, bumpers and grill. Also check the condition of the fenders and rocker panels. If the rockers are shot they can probably be fabed but fenders are going to be another story. No one is making them so if they're gone you'll have some hunting to do.
Over all, if its a pretty solid car and the important stuff is there then it's probably something you can work with without too much trouble.
Good luck.
Old 07-09-2008, 04:17 PM
I agree with the above posts. Congratulations on your find. Hopefully it will work out fine. Just the fact that it is a DeSoto makes it rare. That fact also means replacement parts are going to be hard to find, so make sure what's there is as complete as possible.
If you have patience, and some fabrication/body work skills, this would probably be a neat thing....or give you the opportunity to learn these skills.
I'd be real tempted.........
Old 07-09-2008, 08:16 PM
chlsnk's Avatar
I feel really lucky because my grandfather my uncle my cousin and now I (my cousin and I are still in training) Are body men and have been around cars since we could turn a wrench so I do feel blessed.
As far as parts it shouldnt be to hard because crysler plymouth dodges used the same parts and preformance parts can be found on boats because the flat head six was popular to put in boats back in the sixties and seventies.(or at least from what I have read)
Does any one know what lug pattern this car is I might have some wheels with decent tires on them and They could stay on until I get new rubbers.
My plan if I get it is to get it running get the rust stopped and a temporary paint job on it and use it to get around with until I get my other car running and then finish the resto on it.
Old 07-09-2008, 09:08 PM
Wiki Edits: 31
wheel pattern is standard Mopar. 5X 4 1/2".. also Ford and AMC
Old 07-09-2008, 09:21 PM
chlsnk's Avatar
Okay thanks this will really help me out.
Old 07-09-2008, 09:59 PM
They are fairly rare. They are not all that much in demand. They are 6 volt. They are considered by some to be troublesome if daily drivers. It is 61 years old so parts will not be at Advance, Auto Zone and O'Reily's. It should have a 236 ci engine with a whopping 109 HP. The ones with " fluid drive " leaves a lot to be desired.
If you are not a good mechanic now ... you will BECOME one if you keep the Desoto running long.
Old 07-09-2008, 10:24 PM
chlsnk's Avatar
Where can I get a 6 volt battery and can they be converted to 12volt? Does any one know the original colors?
Old 07-10-2008, 08:32 AM
345 desoto's Avatar
Location: Skaneateles, NY Summer/Port St.Lucie, FL Winter
That would be a 6 volt POSITIVE (+) ground system and yes, they can be converted to 12 volt negative (-) ground with a minimum of work. Chrysler parts of that era will interchange...for the most part, but not Plymouth/Dodge...
Old 07-10-2008, 08:52 AM
chlsnk's Avatar
As so they are like british cars with a positive ground eh? What does it take to convert one to neg 12v ground?
Old 07-10-2008, 08:58 AM
345 desoto's Avatar
Starter, generator, light bulb change, and resistors for the gauges or any accessories that are electric...
Old 07-10-2008, 09:51 AM
chlsnk's Avatar
Can you still get 6 volt batteries? A quick search turned up nothing.
Old 07-10-2008, 01:06 PM
345 desoto's Avatar
NAPA Commercial and Tractor batteries...
Old 07-10-2008, 07:20 PM
chlsnk's Avatar
Ah okay thanks.
1928-1932 Desoto, Chrsyler or Dodge Coupe?? iniguy General Rodding Tech 7 11-15-2012 09:52 PM
My NEW Project!! 1931 Desoto 3-W Coupe! :) mistermuscles Hotrodders' Lounge 14 11-01-2005 09:01 PM
47 Ford COUPE ONEGALONLY Introduce Yourself 1 10-03-2005 10:46 AM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 10:20 AM
Hey HRK...47 Coupe? Weimer Hotrodders' Lounge 1 12-16-2002 11:37 AM
