Check to see if you have communication first.
When communication is restored: Purge valves (located on manifold) are common failures. Key on engine off should have system voltage at one wire. With purge plugged in, backprobe control wire (opposite of power wire) and drive vehicle with voltmeter, red lead to backprobe black to ground and batter voltage should toggle. If it toggles and you have system voltage at power wire you verify powers and grounds, and it indicated purge valve issue. Also, some scantools will allow bidirectional control of purge valve. Why do they fail? carbon from canister becomes loose from ever fueling and age and carbon sticks in purge valve. |
| problem, problem, some ideas please | awert | Engine | 2 | 06-21-2009 07:20 PM |
| timming problem?? or carb problem???? helppp | 85 k5 mud truck | Engine | 10 | 06-05-2009 04:59 PM |
| having a wiper problem in my chevy truck, and a taillight fashing problem in my GMC | ChevyJim | Electrical | 5 | 01-28-2006 07:20 AM |
| 95 Camaro fan switch problem / ignition key problem | human_forklift | Electrical | 7 | 10-24-2004 11:37 AM |
| starter problem ? timing problem? | 6speedwagon | Engine | 1 | 08-11-2004 11:37 AM |
