Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Think I got a rear end! WHOOO HOOO!
Old 09-07-2002, 07:42 AM
dmorris1200's Avatar
dmorris1200 dmorris1200 is offline
doesn't play well with others
Post
Or if there's no tag on the rear cover to tell for sure take the cover off. Count the number of teeth on the ring and on the pinion gear. Divide those numbers and that's your ratio. Ex. 30 teeth (ring) divided by 10 teeth (pinion) = 3.00 to 1 ratio. 37 (ring) divided by 10 (pinion) = 3.70 gear set.
BUILT FORD TOUGH
