Think I have the wrong unit. - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2006, 06:56 PM
A while ago I had asked about a hydroboost unit for my 71Chevelle.
I was told a unit from a 93+ Chevy Astro van would work beautifuly, bolt up and be good.
So I got one.
Made the mistake of not looking at the pedal connection before I bought it.
Now im not sure if it will even work.
Take a look at these pics and let me know if I can make it work.
This is what the current booster rod/pedal connection looks like:
This is what my hydroboost rod/pedal connection looks like:
Old 09-08-2006, 09:30 AM
sedan delivery's Avatar
brake booster
if the distance from the firewall to the center of the push rod is different --then you might have to cut and weld the old rod to the new rod. if they are the same try a bushing for you local bearing store if you have one. the bushing can be either brass or nylon. maybe someone else has a better idea. if you have a local brake re-builder in your area you can check with them. if you do any welding keep the rod cool with a wet cloth, or remove it from the unit if possible.
Old 09-08-2006, 09:36 AM
brake booster
if you are putting in a hydro boost in because of low vacuum. you could have installed a vacuum pump form a 85 cad. coup diville, and make a bracket for your engine..just a thought.....
Old 09-08-2006, 01:35 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
The rods do come out, with difficulty, I would match the length of the old one onto the new unit.
Old 09-09-2006, 08:43 AM
I was considering cutting the old rod off and welding it to the new one, but that raises the question of safety, I can weld well but all I have is a hobart 140.
I dont know if it would be adequite for the thickness of steel used on the rod.
Rod is about id say 1/4" thick
aod speedo sending unit ? 56f100 Transmission - Rearend 2 09-30-2005 06:23 AM
Fuel sending unit won't read RodFather Electrical 3 05-22-2005 05:02 PM
Temp Sending Unit? Seon Engine 2 06-23-2003 03:01 PM
Where can I install my water temp sending unit? CHEV66JB Engine 1 05-11-2003 06:15 PM
Oil Sending Unit Assistance MI2600 Engine 3 09-11-2002 07:55 AM
