thinkers question on tall tires n dually rear? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2012, 05:38 AM
HemmiGremmie's Avatar
Last journal entry: 52 truck
Hello
Bout to get my rat rod rear started so here goes. Got a 14 bolt dually rear end going in it. I'm running semi tires on it. There like 41 inches tall. Wat gears ya think would work? Are all posit units set up to work in em? Just curious to yer thoughts. Tnx, hg
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
Old 02-26-2012, 08:31 AM
Irelands child's Avatar
Probably a ratio in the mid fives to compensate for those tall tires and still have some semblance of acceleration - of course, an OD transmission ........
5.13 = 2733 at 65mph
Irelands child
Old 02-26-2012, 08:46 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
what does it have now?
456 or 411?
i think you could live with the 456, if non overdrive trans
Old 02-26-2012, 12:22 PM
Last journal entry: Some More Roll Cage Fabrication
Are you using the stock axles? I don't know if they will be able to hold up to that large of a tire and that much rotating mass. What size are the tires? 22.5 x 11?? I find this idea very interesting, just worried about the axles taking the abuse. Post some pics so we can see what you are thinking.
Good Luck!
Old 02-26-2012, 12:59 PM
& matts38chev
Good Luck!
they should be ok on a street machine
Old 02-26-2012, 05:43 PM
Chk out hemmigremmie1's photo journal build section on here. Tnx for info. HG
Old 02-27-2012, 07:14 PM
The last road tractor that I owned had a direct trans (no od) 2.73 gears, and 22.5 lo pro tires. It turned around 1550 rpm at 65.
tall narrow 14" tires exist? matt167 Hotrodding Basics 1 04-26-2010 07:32 AM
14 bolt dually vs IH dually rear??? HemmiGremmie Transmission - Rearend 2 02-01-2010 08:49 PM
JOIN Hermanatorís Intelligent Thinkers Movement (HITM) Rob Keller Off-Topic 2 02-13-2009 04:09 PM
BBC tall deck question?? Overdriv Engine 2 07-30-2006 08:47 PM
Dually rear end swap slomotion Transmission - Rearend 5 06-20-2004 09:50 PM
