Thinking about a 1989 dodge 4*4 w100. - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-02-2012, 05:11 PM
Last journal entry: Got it running
Thinking of getting a truck to replace my 03 pt cruiser. I only get 14-17 mpg driving around town so a truck won't be much worse. And we have a car for longer trips. So I saw an older dodge truck at a small lot here in town. It ain't perfect, but neither is my car.
But I don't have any experience with Dodge trucks so I don't know what to look for. There is some surface rust on the lower door skins. Cab corners and rockers look ok. One big dent in the bed on the passenger side. So the body needs a bit of work, but it doesn't look half bad from 20 feet. Good enough for a daily driver.
I drive about 3 miles to work, more or less. I don't have a truck, but you would be surprised at what I can get in that pt cruiser. The odometer reads about 93k miles, and my pt cruiser has about 130k or so. Plus the truck is a 4*4 which would be a plus in the winter time.
So what goes wrong with this era dodge truck? It has a 318 motor. What do I need to check or look at closely aside from the fluids and wires? Where do they leak and what goes wrong with this motor? What about electrical issues? What do I need to check in the drive train?
Not sure if this should have gone here or general rodding, but this ain't really a hot rod so I thought maybe here was best.
Old 12-02-2012, 06:35 PM
poncho62's Avatar
Wiki Edits: 5
318s are good engines as are the Torqueflite trans.....The bodies on Dodge trucks generally suck. Electrically, the ignition systems are good, only trouble I ever had was the ballast resister goes at times. Carry a spare
Ontario Rodders
The Following User Says Thank You to poncho62 For This Useful Post:
silentpoet (12-02-2012)
1989 shelby dodge dakota hemibee1 Electrical 1 01-27-2012 05:59 PM
Just Thinking moontanker Off-Topic 7 09-25-2011 11:56 AM
Just Thinking. DoubleVision Hotrodders' Lounge 3 12-31-2009 07:58 AM
What was I thinking??? Blazin72 Hotrodders' Lounge 6 01-11-2007 06:33 AM
What Are They Thinking? 357ford Engine 61 10-21-2004 05:41 PM
