Thinking out loud about adhesives - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-21-2008, 05:18 AM
Old Fool's Avatar
I have never used any of the panel adhesives available today so I have a few ideas and notions that may be incorrect.
Currently on my mind is using panel adhesive in place of welding in patch panels.
I realize there will be a height difference and an edge to deal with, I am curious about durability over time of the bond in an overlap joint such as this versus being used in a pinch weld area as I have seen it used.
as always, Thanks guys!
Old 11-21-2008, 05:35 AM
No durability problems and the only drawbacks is if not done properly you could see a ghost line where your seam is when there's temperature changes and also there is limited adjustability (hammer&dolly work) that you can do after the cure. Spend the time to fit it properly before bonding the parts! Often times when the car sets in the sun a faint line will appear then dissappear when it cools. There are ways to avoid this though and you should fit the panels so there's some room for a fiberglass reinforced filler over the seam. Also grind the patch panel edge to a knife edge taper and have 1" of overlap for the bondline. Go to Fusor's website for some good technical info. And with a lifetime guarantee it makes sense to use it in many situations.
Old 11-21-2008, 01:29 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
What Bob said!!!..good stuff that adhesive..And saves some of us time and frustration trying to weld thin metal..
Sam
problem...thinking it might be electrical. hotrodlovr Electrical 1 09-11-2007 07:33 PM
ground strap over thinking tomthecomic Electrical 1 08-12-2007 08:17 AM
adhesives jackodom Body - Exterior 2 01-12-2007 04:51 AM
Exhaust too loud? Fil Engine 7 10-06-2003 11:15 PM
Fusor adhesives axle bastard Body - Exterior 4 06-05-2003 12:53 PM
