Thinner head gasket to increase compression ratio? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2004, 10:16 PM
I am sure this has been discussed before but I can't find it. Your help would be greatly appreciated.
What is the approximate amount of increase in the compression ratio of a Mopar 360 if the head gasket thickness is decreased by .020?
Old 05-04-2004, 10:41 PM
killerformula's Avatar
Last wiki edit: Carburetor
Last journal entry: Clean up
Wiki Edits: 3
Not much, not even half of a ratio. You dohn't want to do that to increase compression anyway, it will screw up your quench and make your motor run like shiz.
K
Old 05-04-2004, 10:46 PM
DoubleVision's Avatar
Thinner head gaskets increase quench, but honestly, as Killer already said, I`m not sure just a head gasket change would be worth all the effort for a few horsepower gain. If the gasket is a shim type you`ll have to make sure the heads and block are flat, since shim type gaskets are less forgiving than after market gaskets. If the pistons are dish tops it wouldn`t have any effect on quench anyway, and a less than a half a point of compression increase you likely wouldn`t even notice.
Old 05-04-2004, 10:53 PM
Sudden Psycho 31's Avatar
to get an acurate measurement we need more info...
if i asked how much water would i get if i took out 2 inches out of a sink?
how big is the sink, kitchen, bathroom, etc ... you get the idea
to calc it
1. head chamber volume
2. head gasket bore
3. head gasket thickness, compressed ( your -.020 part)
4. piston down bore, (zero if decked completely)
i ran a quick scenario, with all assumptions
1. 74cc
2. 4.1 in
3. .050 in
4. .020 in
equals 9.29 compression
just changing 3. to .030 (your .020 less) equals 9.71 so you gain a little under .4 compression.
beter heads will chang that .020 more drastically
64cc and zero decked will gain more than .7
hope this helps
later,
31
