Thinning filler - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-25-2005, 10:10 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
Thinning filler
What can I thin body filler with?
I know they make a product for this but
some people are using lacquer thinner and
I was wondering, is that ok?
Old 05-25-2005, 10:46 AM
STUPID is as STUPID does...
You would be much better off getting a polyesther putty like Icing or Evercoat. They are pretty thin, go on nice and sand out real easy. Screwing around with the bondo may cause adhesion problems down road...
Mark
Old 05-25-2005, 11:39 AM
Silentlion_69's Avatar
Duck Tape & WD 40
Last journal entry: No more Vehicle
quick question but why would you want to thin out body filler? wouldn't that make it hard to apply? ( wouldn't the filler drip off and stuff )
Old 05-25-2005, 02:09 PM
You can use Evercoat's Plastic Honey if you need to thin your filler, but IMO you'd be way better off using a polyester glazecoat instead. Evercoat's easy sand works good, Upol's Dolphin Glaze, many similar products out there. Laquer thinner will give you a shorter window for good spreading, plastic honey will make for a tackier top surface unless you let is set longer.
Just buy some EasySand or Dolphin glaze. Or you can switch to Evercoat's Rage Extreme which is a very smooth spreading medium bodied filler. Bob
Old 05-25-2005, 02:59 PM
Fiberglass resin works well also.
Old 05-25-2005, 03:09 PM
roger1's Avatar
See this thread about polyester primer:
http://www.hotrodders.com/showthread...0&page=2&pp=15
Old 05-25-2005, 07:03 PM
Bob, you like that xtreme filler? I just started using it at work and soon found myself wishing for some Gold. I thought it was too thin for filler, ran too much.
Althou it does elimate the need to two products, but in IMO it makes the "filler" process a tad harder.
Old 05-25-2005, 09:45 PM
mrcleanr6's Avatar
i thought the same thing!!! i tried a gallon and went back to the gold. the xtreme is more expensive and is supposed to be pinhole free. i didn't notice any difference in that aspect. i would much rather use gold then metal glaze or poly primer.
Old 05-25-2005, 10:18 PM
I like the extreme, the gold and regular rage work just fine and can go on thicker for sure, but I haven't had any problems getting the fill I need with the extreme- just spreads so much nicer IMO, less prone to pinholes too. The regular rage and gold seem to sand better while soft/green but most of my sanding is done after full cure so makes no diff to me. All three are good.
Old 05-26-2005, 04:37 AM
jcclark's Avatar
The Penny Pincher
The reason I was asking about thinning is I have a whole gallon of
Dyna-Glass that has thickened up from drying out.
I just wanted to know if lacquer thinner was ok, the fiberglass resin
sounds good, I have some of that. Thanks all.
Old 05-26-2005, 06:44 AM
roger1's Avatar
I would use acetone. I believe it mixes with polyesters better than lacquer thinner.
Old 05-26-2005, 02:32 PM
Buy some new filler and keep the lid on tight, toss the old dried up stuff.
"Basic of Basics" How do you properly apply filler? Centerline Body - Exterior 2 02-10-2006 12:22 AM
Wheel Well Rust/Body Filler Help Oddball Body - Exterior 19 12-17-2004 03:33 PM
Body Filler do's & don'ts Ron M Body - Exterior 2 09-07-2004 05:00 AM
Got a filler question here Bluepen Body - Exterior 2 04-18-2003 04:40 PM
Body Work trick66 Body - Exterior 5 03-01-2003 01:18 PM
