Start a wiki article on any hotrodding subject:
Then, others help to build it.
Read and write hotrodding articles in the Crankshaft Coalition Wiki.
See 150+ articles, or read The 8-sentence guide.
Hotrodders Bulletin Board > Tech Help > Body - Exterior
  #1
Old 07-08-2004, 06:36 PM
Bluepen's Avatar
Bluepen Bluepen is offline
Just a firefighter
Bluepen's barnstarLast wiki edit: How to title a hot rod
Wiki Edits: 2
Thinning paint for brush on
I'm painting the grille of my '46 chevy Panel and the word Chevy and some lines are embossed into it and I want to paint them a different color to make them stand out. How do I thin the paint to use it for applying the paint by brush? I'm using single stage urethane paint. I've got the small mixing cups but I think if I thin it like normal it would be to thin.
Thanks folks
David
Old 04-07-2005, 11:25 AM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
In my experience automotive paints are already too thin for brush work. I usually let a little sit out in the air to evaporate and thicken up a little so it will cover better. Try it right out of the can. If it covers, great. Thin very sparingly, a few percent at a time if necessary. Be sure to add a little hardener B4 brushing it.
Old 04-07-2005, 08:53 PM
baddbob's Avatar
baddbob baddbob is offline
If you're using a single stage paint that requires a reducer- (paint+hardener+reducer) just skip the reducer. The paint will be a little thicker this way and will harden just fne. Use a brush with very fine bristles. Should work just fine unless it's a coarse metalic. Bob
Old 04-08-2005, 04:19 AM
jcclark jcclark is offline
The Penny Pincher
I agree with the above.
I painted my metal basement windows last year with
acrylic enamel. I added hardener as usual but didn't
use any reducer. I used a brush for oil base paints.
It went on and flowed out unbelievably well, looks like
it was sprayed on. I think it looked better than some cars
I've seen painted. Hmmm, a brush for car painting????
I've done this to other outside metal
stuff before and it's really held up.
I'm gonna do my gutters with it next.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
