third member on a 65 mustang - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-29-2011, 02:03 PM
1965 mustang project
Last journal entry: what are these from??
65 mustang rearend
hey anyone know what other fords 3rd member came with 3.55 or 3.80 gear ratio, and posi that will swap into my 65 mustang ????? thanks in advance !!!
Old 12-29-2011, 02:42 PM
Irelands child's Avatar
There is no easy answer to that - you have to prowl salvage yards for 8" differentials (I assume it's an 8"). Some 6 cyl Granadas had 3.40, 3.55 and higher Some Pintos had 3.40 and higher numerically. The easiest is to spend a couple hundred, get a new set of gears and a rebuild set of bearings and seals as long as you have a good housing
Old 12-29-2011, 03:55 PM
@ irelands child, hey thank you. how do it read what the tag means on my 3rd member ??? it reads.....
w c z - e
2 80 5cb 911
Old 12-29-2011, 04:05 PM
can anyone tell me what this translates to or give me a linlk to a site that i can do it myself ??? thanks !!!
WCZ-E
2 80 5CB 911
above is the tag on my rear end.. also there is casting marks on the housing that reads......
5B11
0 10.
im wnating to put posi in it and really dont know much about this !!
THANK YOU ALL !!!
ID:	61200   Click image for larger version
Old 12-29-2011, 04:34 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
WCZ-E
2 80 5CB 911
5B11
0 10.
THANK YOU ALL !!!
WCZ-E 2.80:1 8 inch gear 5 =1965 C = March B = 2ND week in the month 911 should be the plant code. JMO and it will /should have 28 spline axles also. Actually by the #s it's a 7 3/4 ring gear but still considered a 8 when talking part's. JMO
The WCZ-E should be 7 3/4 Ring gear not the 8 inch gear the 8 will be WCZ-F code.
Cole
Old 12-29-2011, 06:14 PM
@ eloc4311967 so where did you find that out from? and thank you. i want to make it posi. do you happen to know what other fords came with posi that will fit mine ???
Old 12-29-2011, 06:51 PM
Posi rears are very rare for the 8 inch series Ford rear end. That is part of the reason most guys with the 8 inch UPGRADE to the Ford 9 inch. Posi rear are way more plentiful than the 8 inch ones.
Go here and rear about the 8 inch and 9 inch Fords ...
http://www.kevinstang.com/Ninecase.htm
And look for a tag like this on your rear end.
Old 12-29-2011, 07:29 PM
kleen56's Avatar
The 8" Ford in 65 Mustangs mostly came with 2.80 gears which is the numbers on your tags. In 66, Mustangs came with 3.00 gearing. I don't know what vehicles had them but I know I had a 3rd member with 3.25 and my dad picked up a member with 3.80's at the junkyard (maybe got lucky?) I'd take Irelands advice and by a set of ring and pinion gears in the gearing you want and have a rearend shop install them. I'd advice you not to go over 3.50 in the Mustang with the C4 transmission. Anything over that and you'll be taching in the 3K range and higher. (No overdrive).
Old 12-29-2011, 07:50 PM
i got a brand new aod tranny from the transmition depot its the destroyer stage 2. heres what its got...
Includes:
HD Performance Clutches
Free Torque Converter Included 2100 - 2300 Stall
Super Firm Shifts
Transgo Full Race Shift Kit
Performance Competetion Servo "A" (Oversized)
Wide Kevlar Band
Complete Bushing Kit
Remanufactured Pump Assembly
Hardened Input Shaft
Holds In Any Gear to 5800 RPM +/- 200 RPM
Old 12-29-2011, 08:04 PM
eloc431962's Avatar
Wiki Edits: 37
If i was you i would also have to say go Irelands route on this or go to a 9 inch out of like a 67 mustang or something. JMO
Cole
Old 12-29-2011, 08:08 PM
it's not what you asked for but the explorer 8.8 is almost the perfect size for the '65-'66 if you cut down the long side and use two short axles. 31 spline, limited slip, disc brakes, various gear ratios to be had at the junkyard for cheap. i bought one for $125. add another $150 or so to have it shortened (or do it yourself for less).
as for the 8", there are rebuilt units on ebay for $600-$800 with the gear ratio you need. they're nearly impossible to find in junk yards.
Mustang II cross member install on F100? ZX2fst Suspension - Brakes - Steering 3 12-14-2011 09:45 AM
Mustang 351 mustang install 74chevyflat Engine 13 04-29-2010 07:30 AM
How do you connect a 66 Mustang AMP gauge to a 65 Mustang wiring haress? ttufo Electrical 3 04-22-2010 05:58 PM
New Member- 1966 Mustang Restoration 3reynoldss Introduce Yourself 2 08-10-2004 08:50 AM
mustang 11 cross member 38harry Suspension - Brakes - Steering 0 01-28-2004 12:47 PM
