Thirsty auto transmission 88 gmc - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-14-2012, 09:24 PM
I have a 1988 gmc sierra 4x4 that is using alot of automatic transmission fluid with no puddles showing under the vehicle. I have no idea where the fluid could be going without any leaks showing underneath. Any info would be greatly appreciated.
Old 07-14-2012, 10:06 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Check the fluid level of your t-case. I bet it is over full.
Seals between the transmission and t-case get hard. The trans fluid passes into the t-case
Old 07-14-2012, 10:11 PM
Wiki Edits: 85
If your transmission has a modulator, check it. A bad modulator could allow the vacuum to suck transmission fluid to your motor where it is burnt with the fuel.
Auto trans swap into 79 GMC 4WD? Truckhead Transmission - Rearend 7 12-20-2011 01:18 PM
97 gmc 1500 97 GMC 1500 Internal transmission squeak Longbox262 Transmission - Rearend 5 06-25-2008 05:41 PM
O/D auto for '91 GMC S15 2.5L 4 cyl? XNTRCI-T Transmission - Rearend 9 04-24-2008 10:50 PM
400 auto tranny in a 72 GMC sprint. gearheadgirl Transmission - Rearend 1 02-18-2003 11:17 AM
