I have a '78 Nova Custom with a 250 L6. I have the service manual for that year and it tells me that I either have a THM 200(???), CBC 350 (??)or a TH350 3-speed auto trans. What the heck are the THM 200 and CBC 350? And are they any good. Or even better, how do I tell which I have (I'm almost certain it's not the TH350). Anyone who knows what these things are and comments would be greatly appriciated by me. I am planning a v8 swap and need to know if I am going to have to do a tranny swab as well.
Thanks man, that helps. I'm, glad to hear that the TH200 was put behind the 305 because that's probably is going to end up in place of the 250. I was also unaware that GM used a universal bellhousing bolt pattern on thier TH350. I was under the impression that only the 200-4R and 700-4R had a few units produced that had the special bolt pattern.
When I was in Tech College, I had a 79 Malibu Classic that had a 200 and I wanted to swap it over to a 350, my instructor said "don`t do it, the 200 has a 3.08:1 first gear and the 350 has a 2.52:1 first gear, the reason is because of a low power engine, and very high rear end gears like in the 2.23 or 2.73 area. you install a 350 and don`t gear it lower in the rear, it`ll be a dog off the line with that little 305 your running"
Also this was when i learned of a CBC350, which i think could also mean Chevy - Buick - Caddy, because we have a caddy 472 bolted up to one, but I don`t know if a buick and a caddy are the same pattern or not. I like these transmissions because they`ll accept a few different engines. which is good for someone like me who likes to sometimes try something different. |
I think I would skip the TH200 if you have other options. I spoke with several mechanics and most were reluctant to even consider rebuilding it. It's my understanding that these trannys were pretty weak and parts are hard to find.
