thm 200 toThm350 question. - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-23-2002, 05:39 AM
Post thm 200 toThm350 question.
If I replace my Thm200 with a Thm 350, what else must be changed? TIA
Old 08-23-2002, 09:57 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
As I recall the 200 is identical to the 350 except for a missing clutch pack and such inside. Should be a direct replacement.
Old 08-23-2002, 10:44 AM
Thumbs up
[quote]Originally posted by willys36@aol.com:
<strong>As I recall the 200 is identical to the 350 except for a missing clutch pack and such inside. Should be a direct replacement.</strong><hr></blockquote>
Finally, good news. BTW, You have one beautiful car!
Old 08-23-2002, 10:48 AM
DragLinkscc's Avatar
New Member
Post
Ive got a 200 that I cant give away! along with a 305 and a caprice wrapped around it! want one? ahhaah 200/350 swap no problem
Old 08-24-2002, 10:10 PM
E.T. divided by $ spent= Speed
Post
The tranny mount is in a differant place either forward or backward(can't remember)you'll have to move the X-member.Also the TH350 needs a modualator vac line just run a line from the intake to the modulator. Basically a direct replacement.
Old 08-24-2002, 10:14 PM
Post
Can't remember if the TH350 and TH200 had the same converter pattern.Make sure you have either the same size converter bolt pattern or a dual pattern flexplate.
