thm 400 - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-24-2007, 11:14 AM
thm 400
I have a thm 400 out of a 4x4 the output shaft is broken
I am having trouble finding one
What other tran will fit
it is out of a 1988 Chevy with a 454
Old 11-24-2007, 01:29 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
1988 1 ton truck?
No other trans bolts in place since this is a married trans - t/case setup.
The out put shaft you need is the shortest 4x4 shaft GM used in the OEM setup. A trans shop would be the easiest place to look. I doubt GM would service this part any longer.
Old 11-24-2007, 04:22 PM
jakeshoe's Avatar
I probably have one of the shafts you need.
Measure your existing shaft and let me know.
I rarely use the 4x4 stuff so you can have this one for shipping.
Old 11-26-2007, 08:24 AM
thm 400 output shaft
hello Jakeshoe
the length of the shaft is approx 7"
this is the over all length the shaft plus the gear
the address here is
D marshall
Po Box 35
Emsdale Ontario
P0A 1J0
2200 old hwy # 11
if you could please get a shipping cost
Thanks
a budget 383 stroker build using a stock 400 GM Crank Mustangsaly Engine 7 10-15-2007 01:57 PM
Help on THM 400 vuka Transmission - Rearend 4 08-28-2007 07:42 AM
383 or 400?? KFXrider88 Engine 7 06-13-2006 06:45 AM
THM 400 Questions Fast Orange Transmission - Rearend 3 03-07-2006 08:09 AM
thm 400 mount 88 olds Transmission - Rearend 0 11-11-2003 09:48 PM
