Thm-400 In G-body - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-31-2006, 09:46 PM
Redman Racing
Thm-400 In G-body
i am about to pull a THM-400 for my g-body. I wanted to know what I have to do for the drive-shaft(lenthwise and do most yokes yous the same u-joints as original)? I will be taking the slip yoke that came with the trans. OH yeah what tail-shaft should I be looking for. I pretty sure when you use a THM-350 you use the 6" tail but I am not to familiar with the 400.. Is the 200r4 torque convertor interchangable.
Thanks for any advise!!!!
Old 05-31-2006, 10:34 PM
jakeshoe's Avatar
You will want the short tailhousing. You're crossmember should work with minor mods, you will need a TH350/TH400 converter, the 200-4R will not interchange.
You also need the larger yoke, 32 spline.
Old 05-31-2006, 10:38 PM
Redman Racing
damn I knew it. Just paid 400 for my convertor last year. Crossmember is a G-force 2004r/400.
Old 06-02-2006, 11:34 PM
Redman Racing
Anyone else have any suggestions???
Old 06-03-2006, 07:14 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
For what?
jakeshoe mapped it out for you..... t-400 use the short tail housing unit.
Yoke is larger 32 spline unit.... U-joints depend on what yoke you buy, still may not match your current drive shaft.
Drive shaft will need to be modified
Cross member will need work.
200r4 convert will not work in t-400
Old 06-03-2006, 10:05 AM
Redman Racing
thanks then Jakeshoe.
T bucket body demensions needed lowROLLERchevy Body - Exterior 3 03-21-2006 06:20 PM
body on or body off IROC100 Body - Exterior 2 02-07-2006 07:47 PM
Chop and channeling. how to....? baugh353 Body - Exterior 15 02-07-2006 07:21 AM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 06:50 PM
400 turbo valve body diagram? project69ss Transmission - Rearend 0 07-14-2003 01:22 PM
