THM 400 Questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2006, 03:20 PM
Fast Orange's Avatar
THM 400 Questions
Here are a couple of questions for the tranny experts-
1) I've got a 85 Chevy 1 ton truck,350 engine,turbo 400 trans. It blew a head gasket, so I pulled the heads and replaced the gaskets.After the engine repairs were done, I took the truck out for a test ride and the trans wouldn't shift out of low gear. I checked for vacuum to the modulator-20 in. at idle.I changed the modulator,still won't shift.It makes no difference what position the shifter is in. The truck was not overheated when the head gaskets went,and I flatbeded the truck back to my garage.The tranny worked properly until the gaskets went. Any ideas?
2) I've got another turbo 400 in my shop that I pulled out of a simular truck.It's been sitting on a shelf for about 3 years,with no fluid in it.It too worked right when I took it out of the other truck. I was checking it out to see if it would work when I noticed that the larger of the input shafts does not turn by hand-even with a pair of channellocks,I can't turn it.The inner shaft and the output shafts turn OK.This trans was stored without a convertor or dipstick tube,with holes open. Do you think this trans could be installed as-is,with new seals and fluid/filter,or should the large input shaft(pump?) turn easier?
TIA,George
Old 03-03-2006, 06:39 PM
problem #1...check the gear on the governor..located under small steel side cover held on with 4 bolts. gear may be stripped...
problem #2...the larger shaft should not turn..ever...it holds the stator in the convertor.
Old 03-06-2006, 05:13 PM
61 chevy-
You hit the nail right on the head-
I pulled the governor and found the gear broken off at the roll pin.I put the governor from my spare trans. in the one in the truck,dropped the pan and removed as much of the old gear that I could find,put in new filter and fluid.The truck now shifts right. As long as none of the remains of the old gear get in the wrong place,I think it'll be OK.
Thanks for your help-I owe ya one,
George
Old 03-07-2006, 08:09 AM
your welcome.
Just bought 400 chevy, build idea and some questions? Warrant Engine 10 01-11-2006 07:50 AM
400 Small Block Questions Dark Jester Engine 3 07-09-2005 12:02 AM
400 SBC project - questions... Mad Maggot Engine 24 01-05-2005 10:24 PM
questions on 400 SB shockers69 Engine 3 03-18-2004 09:41 PM
turbo 400 questions? HemmiGremmie Transmission - Rearend 4 02-09-2003 11:42 AM
