Thm 400 Whining - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2011, 09:06 AM
CADI70's Avatar
Thm 400 Whining
I've got a THM400 that has a whining problem. It also doesn't shift at all when cold. The car must warm up to shift. The warmer it is the better the shift. The car whines at idle and in park very loudly and seems to lessen when in gear. It definitely gets better when warm but never completely goes away. Also even when warm the shift seems to shutter. Any ideas on what my problem may be?
Old 10-19-2011, 03:24 AM
SSedan64's Avatar
Sounds like the Seals are Hard/Brittle causing pressure loss, Pump whine.
Time for a Rebuild.
Old 10-19-2011, 08:11 AM
CADI70's Avatar
I don't know much about tramsimissions but I do fine with motors. Is this something I could do myself? I was thinking that the pump might be bad. How hard is it to replace?
Old 10-19-2011, 08:38 AM
SSedan64's Avatar
Replacing the Pump is fairly easy. A Rebuild is a little more complicated and probably what's needed.
(An ATSG Manual is a good Idea.)
http://www.crankshaftcoalition.com/w...0_Rebuild_tech
http://cogpro.com/chapters/P-TurboHydraMatic/index.htm
" Links thanks to 'Jake' " from here > http://www.tpub.com/content/trucks1....9-2320-280-34/
Pump Inspection:
http://www.tpub.com/content/trucks1....0579760837.htm
http://www.tpub.com/content/trucks1....0579760838.htm
http://www.tpub.com/content/trucks1....0579760839.htm
Pump Assembly:
http://www.tpub.com/content/trucks1....0579760840.htm
http://www.tpub.com/content/trucks1....0579760841.htm
4L60E whining in 2nd 3rd and OD but not 1st vtf_thor Transmission - Rearend 1 08-17-2007 10:15 PM
Whining Alternator? locomark Engine 7 06-19-2007 01:50 PM
whining in reverse? tinman386 Transmission - Rearend 10 11-06-2006 08:29 AM
I stopped by and everybody’s whining. rs Hotrodders' Lounge 42 11-27-2004 11:57 PM
distributor whining Mr.E Engine 2 01-11-2003 06:15 AM
