THM350 Tailshaft/end Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-11-2009, 09:39 AM
BowTiePride's Avatar
Chevy to the death!
Hi!! I bought a junkyard THM350 out of a 85 gmc 2wd 1500 truck. I'm replacing the stock powerglide in my 67 impala, my only issue is that I bought the 31 (ish) inch long 350 instead of the 28 inch (ish) one, so I must have got one with a 6" tailshaft housing. I don't have all the money in the world, so I was hoping that I could swap tailshaft housings from a correct one at my local bone yard. I can't exchange tranny's so my only option is modify this one or shell out cash for another. And I don;t want to shorten the drive shaft. What all do i need to get/do to swap tailshaft housings? Thanks a bunch
Jake
Keep on rockin in the free world!!
Old 04-11-2009, 10:24 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Need to take the tranny completely apart to switch the output and tailshaft housing.
Look around the 'yard for a drive shaft that's the right length- you may get lucky. Check vans and trucks. Sometimes they have shorter d-shafts because they used the long tail tranny.
It's that, a different tranny or shorten your d-shaft. Or tear yours down.
Old 04-11-2009, 11:02 AM
Chevy to the death!
What all would I need to swap over if I did take it apart? I work at a Chevy dealer so getting one of the guys to help me wouldn't be hard
Old 04-11-2009, 11:11 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Tail shaft and housing are the main parts.
I honestly do not recall if anything else is required, both times I've done it I had both trannys in front of me (donor and recipient) and a Chevrolet factory service manual, so having the right parts and info wasn't an issue.
Old 04-11-2009, 11:21 AM
Chevy to the death!
Thank you VERY much you've been a tremendous help!! One more thing, is there a factory service manual online somewhere where i can dopwnload it as opposed to buying the whole thing? Or could a just use the manual from the 82 chev van?
Old 04-11-2009, 11:35 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Here's a post from this forum that has some info that will answer the question about a manual as well as shows a tranny being built.
Hope it helps- http://www.hotrodders.com/forum/th35...ch-145361.html
THE manual: "This is a chapter from the 77 Buick Chassis service manual, but most of it applies equally to THM350's from other divisions."
http://th350.netfirms.com/browser.htm
Old 04-11-2009, 11:53 AM
Chevy to the death!
That has help insurmountably!! Thank you so so so so sos so so much!! Rock on and thank you again for your help. If I can figure out my damn camera i'll post a swap thread. Thanks, Jake
Old 04-11-2009, 11:57 AM
Will I ever get it done?
Last journal entry: Hood
At 30-11/16", you have a 9" tailhousing version.
I would hunt for a driveshaft that is approximately 3-1/8" shorter than you PG shaft (assuming you have a long tail PG). Just make sure the u-joints are the same. Assuming your salvage yard of choice has a pile of shafts, that would have to be easier than tearing the tranny apart. Just IMHO.
Old 04-11-2009, 11:58 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Glad to help!
BTW, the entire section is there in the link to the GM service manual- nothing's missing, thankfully. I will edit my earlier post to reflect this.
This is what was said about the service manual:
Old 04-11-2009, 12:02 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
X2!!!
Old 04-11-2009, 02:02 PM
fast68's Avatar
likes chevy trucks & boobies
howdy there
well, 30 11/16" is what is always listed for the 9" th350, but the actual overall length is 31.5"
9" tail is found under 73-up trucks, and in most wagons, with a few '77-79 or so wagons being 12" tail th350, but very uncommon.
good luck!
Old 04-11-2009, 03:11 PM
Chevy to the death!
Which vehicles should I be looking for for a 6" tail? (overall length 28 inches ish, replacing powerglide) anyone interested in trading a powerglide for a 6" TS thm350? Or anyone interested in buying my 'glide off of me?
Old 04-11-2009, 07:58 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
F, G, H X and Y body cars are a pretty safe bet. A bodies '76-'80, possibly earlier as well.
Old 04-12-2009, 01:45 PM
junior stocker's Avatar
Too long of a TH350 trans.
You might try this before tearing into your trans and swapping out parts. Just find another driveshaft that's 3" SHORTER; should be able to look in a Hollanders manual to find one that will fit. No need to shorten your existing driveshaft, just replace it. Anyone see any reason this would'nt work and be easier?
Old 04-12-2009, 06:59 PM
Cape Cod Bob's Avatar
Why can't you take it back to the boneyard and get the right length one you need ?
383 stroker 73monte Engine 13 05-11-2016 12:17 PM
Question about vehical weight and engine question Thuggishruggish3000 Engine 12 03-24-2011 06:22 AM
question about a previouse question elrod1030 Engine 6 03-10-2010 08:35 AM
Switching to 200R Tranny question Gundarak Transmission - Rearend 4 12-05-2003 09:00 PM
nitrous 69BiRd Engine 2 11-28-2003 11:33 PM
