those damn window cranks - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-08-2003, 06:54 PM
New Member
how do i get the window cranks off my 68 chevelle they are really pissing me off
Old 09-08-2003, 08:44 PM
32vicky's Avatar
Tomorrow Will Be a Better Day
1st site
2nd site
Old 09-09-2003, 09:05 AM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Sure hope you didn't tear anything up getting pissed off!!!! All you had to do was ask and ye shall receive. Most all GM's have a little "C" clip behind the crank. If you don't have the tool to remove it then your local parts store does. About every parts store carries them. If you are too cheap to buy one then you probably can shove in on the door panel and take a very small screwdriver and push it off. WATCH WHERE IT GOES!!!! It will flip. If you do not watch it, you will lose it, then you will be pissed off because the door handle won't stay on. BTW the local auto parts store carries these clips also. Good Luck.
Kevin
Old 09-09-2003, 03:12 PM
New Member
alright thanks a lot guys i will go buy one of those remover things today or tomorrow
Old 09-11-2003, 01:44 AM
Where's my Sawzall?
Last wiki edit: Window removal and installation
Last journal entry: More progress...
Wiki Edits: 2
Get a shop rag...
and slide it in between the door handle and trim piece, moving it away from the handle or knob end of the window crank. The shop rag will snag the wire end of the clip, and pop it right off...
Used to do this trick a lot at work, it's very fast...
Doc
Old 09-11-2003, 06:15 AM
New Member
thanks man i will try it out
Old 09-11-2003, 05:15 PM
horvath's Avatar
Acoustic Rock ... for real.
Last journal entry: About Fusible Links
Once you get them off, you may want to replace them with after-market jobs -- same handles, only with a set-screw instead of the C-clips.
Alan
54 Chevy Pickup
