-   -   For those running water meth injection on 6 or 8-71 (http://www.hotrodders.com/forum/those-running-water-meth-injection-6-8-71-a-230760.html)
33Willys77 03-15-2013 01:48 PM
I plan on placing the injectors in the carb adapater plate. How did you place yours? One in front and one in back so it sprays more across the rotors, or on the sides?
Would it make a difference to put them in a downward angle?
68NovaSS 03-15-2013 06:33 PM
3 Attachment(s)
I put them in from the sides, and don't feel it makes any difference pointing them down. Depending on the thickness of your carb adapter, it can be a challenge drilling and tapping the holes, be sure you're centered in the baseplate/adapter.
33Willys77 03-15-2013 06:52 PM
Beautiful and with pictures!!!! Thanks!! My plate is 1" and is square, so it should not be a problem drilling a tapping. Just dont see much info on these on the net. I hope the results are worth it, but using it more for insurance. A Hemi is no cheap motor to build.
