For those running water meth injection on 6 or 8-71 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-15-2013, 01:48 PM
33Willys77's Avatar
I plan on placing the injectors in the carb adapater plate. How did you place yours? One in front and one in back so it sprays more across the rotors, or on the sides?
Would it make a difference to put them in a downward angle?
Old 03-15-2013, 06:33 PM
68NovaSS's Avatar
Wiki Edits: 9
I put them in from the sides, and don't feel it makes any difference pointing them down. Depending on the thickness of your carb adapter, it can be a challenge drilling and tapping the holes, be sure you're centered in the baseplate/adapter.
ID:	72300   Click image for larger version
ID:	72301   Click image for larger version
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
Midnight Sun Street Rod Association
Old 03-15-2013, 06:52 PM
33Willys77's Avatar
Beautiful and with pictures!!!! Thanks!! My plate is 1" and is square, so it should not be a problem drilling a tapping. Just dont see much info on these on the net. I hope the results are worth it, but using it more for insurance. A Hemi is no cheap motor to build.
Water injection did nothing for me spinn Hotrodding Basics 7 09-15-2012 04:36 PM
weiand 177 and water meth on sbc homerj55 Engine 19 06-08-2011 11:18 AM
water meth vs small nitrous shot sheldonw Engine 1 08-16-2008 08:58 PM
nitrous "wet" system ... substitute water/meth in place of fuel ? lowROLLERchevy Engine 2 07-29-2007 09:19 PM
Water injection Mikey_mike Engine 8 09-14-2003 11:35 AM
