For those who need quick heat. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-27-2008, 05:25 PM
41 kustom's Avatar
Quick Heat
I have a 150,000 BTU gas heater in my garage. It's 24x28. I get real quick heat. What I did for the oxegen problem was to cut a piece luan plywood to fit the bottom panle in my window. In that I cut a 8" circle for stove pipe that runs from there to the back of my heater. As my heater runs it sucks fresh air from outside. It dose not matter what the temp of the air is outside, It will blow all the hot air you want. I've done this for years and it works fine. My son has one to. He cut a hole in his garage wall and made a permament mount for his. I use the window so I can shut it when not in use and put my heater up in the summer.
  #17 (permalink)
Old 12-16-2008, 08:55 AM
onemintcaddy's Avatar
Don't forget,,, Using solid fuel heaters will cancel out most home owners Insurance policies. Not to mention how it will make all your tools and floor sweat with moisture if you don't keep it a constant temp.
Spring Cleaning For The Members: Tips Only Racing Hotrodders' Lounge 15 03-13-2008 07:02 PM
Can I use heat to relax metal after stretching? Ripped Body - Exterior 10 11-16-2006 11:36 PM
air con and heat problem help its cold gl perkins Interior 0 10-18-2006 03:13 PM
Starter heat soak-Mopar? Steves66 Electrical 2 06-27-2006 05:00 AM
Effects of paint on cooling components Animal General Rodding Tech 7 03-12-2006 05:10 PM
