Valve spring requirements should start with the cam manufacturer's recommendations.
For rockers, I like CC's Pro Magnums, although there are other quality ones too. But I've got nearly 35K street and race miles on mine with no issues whatsoever. This is in a 388 Chevy factory roller motor. Adjustment has never varied when checked and they still show no discernible wear. They're also rebuildable whenever the need finally arises. |
Run the springs Comp Cams recommends. If they recommend dual springs take out the inner spring or use weaker springs to break in the cam. Be sure to shim the springs to proper installed height during the final assembly. I would use full roller rockers for the horsepower gain. A 1.6 ratio rocker arm will give you a little more lift and duration, but if those duration numbers are at .050 I don't think you'll need anymore for the street.
I'm curious, how did you get your static compression ratio of 10.4-10.5 with flat-top pistons and a 75cc combustion chamber? I've run several combinations through the calculator and the only way I can get close to that number using the stats you provided is by using zero deck and a .020" shim gasket, and even then I'm only getting about 10.3 to one, and your quench would be dangerously tight. Using other more common combinations like a zero deck and .039 gasket, or stock deck and a shim .020 gasket, I get CRs between 9.5 and 9.8 to one.
Can you provide the rest of the relevant numbers like gasket thickness and bore, deck height, and maybe valve relief size? Maybe I've overlooked something, but you'll need 10.4-5 compression for that cam and I want to make sure you have it. In fact, Comp recommends 11:1 CR for that cam. |
http://www.linderothstryckeri.se/ltr...taticcalc.html the bore is 4.030 (inches) the stroke is 3.75 (inches) gasket thickness .040 (inches) deck height 0 (inches) valve reliefs 5 (cubic centimeters) I could be getting this wrong, but the combustion chamber volume in CC's is 121.6025..thats the volume of the stroke/cylinder, which would be (3.1416 x 2.015^2) x 3.75 x 2.54(inches to centimeters) .. am I missing something here? lol, i'm getting 6.8.. |
http://www.kb-silvolite.com/calc.php?action=comp
try this one are you entering your piston .005 or just 5 cc |
Some calculators require you to enter negative values for valve reliefs and others require you use positive numbers. That could affect your values.
I get 9.9:1 on this calculator http://www.bgsoflex.com/cr.html |
http://www.bgsoflex.com/cgi-bin/cr?c....00&gskt=0.010 |
If you haven't already built the shortblock, now is the time to consider a different piston. I would lean toward the dished piston with 64cc head instead of a domed piston with a 75cc head. Domes slow the flame front killing efficiency and requiring more ignition lead. |
If you stick with the AFR heads, you can just drop down to their 65cc version. You'll retain your good quench and allow you to keep your current pistons if you already bought them. The only possible issue would be your new compression ratio of about 11:1 even. Perfect for your cam, but probably risky if you're planning on using pump gas. Then again, are you sure you want to use that cam if you won't be running the recommended static compression?
I should stop answering questions late at night after a long day, I seem to lose the ability to read....LOL. I was thinking flat tappet cam, not roller.
| 406 combo, your thoughts | 406 ss monte | Engine | 21 | 06-15-2008 07:19 PM |
| Which Carb 383 SBC | sexypizzaman | Engine | 14 | 02-21-2008 04:33 PM |
| Oil Pump for 383 SBC?? | 89SDime | Engine | 2 | 03-13-2006 01:40 PM |
| please Check my 383 combo..I need some help | terror385 | Engine | 18 | 01-17-2004 06:47 PM |
| Check my 383 combo..I need help | terror385 | Hotrodding Basics | 7 | 01-17-2004 03:22 PM |
