thoughts on this 427 combo - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-17-2006, 11:03 AM
bigwildgrin's Avatar
Rooster
I'd appreciate anyones thoughts on this engine combo. Only the block has been purchased, so its not too late for me to change anything. Here's what I'm planning:
I have a big block chevy block, bored .30. I'm thinking a steel crank and rods, forged pistons. I can get this combo in about any compression ratio; I'm thinking about 10:1. A Comp Cams .294 duration with .595 lift, solid lifters, edelbrock aluminum rectangle port heads, edelbrock dual four intake with two 600 carbs. Headers of course. All this will go into a corvette that weighed 2100lbs with a small block in it and a near empty tank. The tranny is a muncie m21 and the rear is a 4:11, although this is much too low for my taste and will be changed, probably to a 3:08. The car does not have power brakes, but the headlight doors and wiper doors are vacuum. It would be okay if I had to rev the engine a little to get the vacuum doors to open, just so long as they will open. This is a street car, but it's not going to be driven by grandma.
And also as a final thought, I have a 454 forged crank, new in the box that I was considering using instead of buying a 427 crank. Any thoughts on this with the same combo?
thanks in advance
Old 02-17-2006, 11:21 AM
WV hillbilly
Last journal entry: PTL 220CC
considering the rectangle port heads I would go with a 454, Im currently in the middle of just such a project, the car is a 65 chevelle, 10:1 454, with the large oval port heads. I pocket ported the heads, and have installed 2.25x1.88 valves and shaved the heads to attain 10:1. the cam is a ISKY mega HDY 280, the intake is a weiand action+ (due to hood clearance) whitch I gasket matched and did some minor cleanup on. The whole idea was a stump pulling monster that he could drive to car shows etc.. the car has a 12 bolt, 4.10 gears, and 275/60/15 rear tires. Th350 and a TCI breakaway torque converter. this combo should pull like a freight train to 5800.
I will add photo's of this project soon, along with the performance.
2wld4u
409 Corvette? MI2600 Engine 18 06-04-2005 09:34 PM
my 350 engine combo questions mcmike Engine 7 01-16-2004 11:00 AM
could use a little advice on this Engine combo I am putting together 427 cui ProStreeter 67 Engine 2 09-07-2003 06:22 PM
engine combo...thoughts? redcamaro4spd Engine 3 07-12-2003 01:57 PM
which engine combo? 86SSman Engine 6 03-05-2002 05:22 AM
