thoughts on this build?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-28-2008, 07:38 PM
Looking for input on this proposed engine build. Is this to much cam ? or should I use a larger intake runner ?
4 bolt studed mains
3.750 stroke 4340 eagle crank
6 h beam eagle 4340 rods
Deck clearance .016
-16cc dish Mahl pistons , coated gapless rings
Hp coated bearings
Coated cam bearings
Digital balance
Dart pro 1 aluminum heads 72cc chamber and 200cc runners 2.02 intake and 1.6 exhaust p/n 11411112p Max lift of .620
Comp cams 12-704-8 intake duration 255 exhaust 262 @.050 with a 114 lobe separation mechanical roller tappet lift is .575
Roller rockers 1.5
Holley double 750 pumper from the carb shop , flows 930cfm
Weiand 144 supercharger with manifold
Milodon hv oil pump
Msd retard box
Msd 6al ignition
Head gasket compressed to .040
Old 02-29-2008, 05:12 AM
DoubleVision's Avatar
I take it this is a race engine? Still need more info, what tranny? what rear gear? 1/4 mile? 1/8th mile?
Old 02-29-2008, 02:53 PM
The trans is th350 with a shift kit and a continental convertor with a 3000 stall , ford 9 inch rearend with 3.9s in a 3000 lb curb weight nova . Its going to see some strip time but will also be street driven . I may well change the rearend gears as I think I may run out of gear before I run out of track.
Old 02-29-2008, 03:05 PM
RippinRon's Avatar
I would suggest tightening up the quench. Right know you would have .056" with a .040" head gasket. You could use clevite #5746 .026"/4.100" that would give you .042" which is in a better range. It will raise your compression some but will be more detonation friendly.
Here's where I'm at with my 383 build Malibu73 Engine 17 12-06-2009 08:56 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 09:36 AM
build a moter or buy a car first? Tryin2MakeIt Engine 19 12-13-2006 09:43 PM
350 build up opinions? Artemis Entreri Engine 17 08-09-2006 01:48 PM
Build your own frame? Any basic thoughts? Madd Syntst Suspension - Brakes - Steering 9 11-28-2002 09:00 PM
