thoughts on this build - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-09-2008, 07:47 PM
this hobby is expensive!
check out this build for a 383 and let me know what you think. feel free to criticize i can handle it.
eagle rotating assembly forged steel crank h-beam rods
forges aluminum flat top pistons @5cc
6" rods
11:1 compression with 64cc heads
9.7:1 with 76cc heads
dart iron eagle platinums
200cc intake ports
64cc combustion chamber
2.02" int/1.600" exh valves
.620" max lift
comp cams xtreme energy camshaft
hydrualic roller
lift .510"/.520"
duration 282/288
rpm range 2200 to 5800
edelbrock rpm airgap
750 carb edelbrock or holly
Old 11-09-2008, 08:07 PM
so going with the 72 or 76cc combustion chamber heads would probably be better. that makes sence and it probably wouldnt hurt me power wise either
Old 11-09-2008, 08:26 PM
1962 chevy truck long bed. 3:73 gear 2000-2200 stall in a 400 turbo
Old 11-09-2008, 08:40 PM
Banned
I disagree with picking it last, the cam should be picked partly on what compression you'll be running. I pick the engine parameters (bore and stroke) then the heads, then the pistons, pick the gasket for quench, see where the compression falls at and then pick the cam. The reason I pick the pistons and see where the compression falls is because there is a lot more of a restriction on piston dish/dome volumes than there is on cam lobe profiles. If I know I want 4vr flat top pistons with a 64cc chamber on a sbc 355 with .40 quench then I can pick my cam to match.
HOWEVER some initial toughts on cam choice need to be made before piston selection so that we know about what we want (trucks get 9.5:1 rather than 10.5:1 for example due to higher loading and the desire for a smaller camshaft to move the torque band down).
Old 11-10-2008, 12:57 AM
techinspector1's Avatar
Wiki Edits: 326
383
Dart Iron Eagle 200
Performer RPM
750 carb
1 3/4" headers
9.70:1 SCR
CompCams XR270HR 270/276, 218/224, 0.528"/0.535" (1.6 rockers intake and exhaust), 110 LSA, installed retarded 2*
RPM HP TQ
2000 153 403
2500 194 407
3000 248 435
3500 311 467
4000 370 485
4500 419 489
5000 458 482
5500 472 451
6000 461 403
Over 450 ft/lbs 3200-5500
Calculated using the following flow figures for the heads......
.200 129/114
.300 186/145
.400 229/164
.500 261/172
.600 252/174
Tried 7 different cam grinds. More cam will make a little more horsepower, but the bottom end torque goes away. This cam is the best all around choice. Use the 2000-2200 stall converter you mentioned previously. Plan to buy tires often. (This combo makes 360 ft/lbs @ 1500)
Old 11-10-2008, 07:42 AM
Banned
Originally Posted by F-BIRD'88
Pick the cam based on where you want the motors torque curve to occur.
Not to adjust the cylinder pressure.
That does not work. You just end up with a over cammed, inefficient, less powerfull, fuel hungry, peaky, polluting engine that makes less overall power than it could be. Think about it. If you want to make more power, cam the motor so that the induction and exhaust wave tuning is optimized (volumetric efficientcy) to fill and evac the cylinders as best as possible in the usable rpm range. Over cam it and you're allowing potential air/fuel to pass right thru the motor or get pumped right back into the intake manifold.
Trap as much air/fuel in the cylinder and compress it to a point below the point of spark knock and you'll make more power than trying to compress less air/fuel charge by X+1 to get the power. you'll go faster. on less fuel.
I still don't see where you are getting the "overcammed" theory from. It actaully ends up being right on, more efficent, and more powerful. Its how camshafts are designed from the factory. you pick your opening and closing points and let the duration fall where it may. and the "usable RPM range" is not necessarily as low as I think you always assume it to be. A lot of the guys on here build these projects as toys with 4.10 or steeper gearing, 2500 stall convertors, and TH350 trannys. Which really kicks the usable range up quite a bit.
Your method is probably easier for Joe "First time builder" to understand (which a lot of people on here need), but its not the full picture.
Old 11-10-2008, 08:15 AM
Banned
The example above (intended for a truck. Hello, a truck) is a good example.
Make it 10.7:1 as you promote and it will knock at WOT with full timing. Add valve timing duration in an attempt to lower the tendancy to knock (over cam) and the low end torque goes away (right where you drive a truck most of the time), requireing a high stall converter (not in the builders plans) and a potentually higher rear gear ratio. Now you have a "racey truck" that not going to be fast ( its too friggin heavy anyways) and eats gas.
Over camming a motor does not stop or even tame the tendancy to knock on pump gas. It just makes you a junk motor build that is a lot less than it could be in all respects. and won't last long. It does not work.
You're throwing your money out the window.
Thats called "junk engineering" It's a bad, bad idea no matter what spin you try and put on it.
There are other much better proven ways to allow higher compression ratio with pump gas without the unnessessary compromise, that actually work.
There is a big difference between a well designed and executed high performance street motor for a truck and a "racey truck"
Its far from "junk engineering" its a way to run into the low 11's on mostly stock parts, NA, on pump gas, and still be streetable. And if you run a higher gear, higher stall, and a more powerful engine it will be quicker- there's no arguing that. I wouldn't put a 11:1 engine in a Chevy 2500 with 3.42 gearing, a OD, and 30" tires. But I also wouldn't hesitate to put one in a stripped down S10 with a 700R4, 28" tires and 4.10 gears. A LOT of people build "race trucks" out of those...
And a 250 cam with 11:1 compression is plenty streetable once you put a 2500 stall on it ang match it to some decent gears. It won't drive like a factory fresh cadillac, but it'l still be easy to handle off a stop light.
Old 11-10-2008, 08:48 AM
Banned
who are you trying to kid?
A cam with 250 @.050" won;t idle right in gear with just a 2500 stall.
It will be a real mutt too. It won;t run 11's or even 12's. with a 2500 stall.
and the motor will knock at WOT unless you kill the spark timing.
A motor with a 250 cam needs a 3500 stall minimum.
You obviously have not built to many of these.
Junk science junk engineering. slow truck with a rough idle that knocks unless you run some race gas, is all you end up with.
A 4800# truck will require a 625 to 650hp motor to have any chance of running a 11sec 1/4 mile. Give your head a shake.
S10's when stripped down come in around 3000 pounds. I know that because I built a few of them. And they are light. And that idle is more dependant on seat timing than @ .050" I have a cam I'm putting in an engine I'm currently building that is adv 279/282, but 248/251 @.050". and it will idle in gear with a 2500 stall. its adv power range is 2700-6800 which puts it right at boderline streetable.
Here's where I'm at with my 383 build Malibu73 Engine 17 12-06-2009 09:56 PM
this is a saver.... GM build codes TooMany2count General Rodding Tech 24 11-23-2009 10:36 AM
build a moter or buy a car first? Tryin2MakeIt Engine 19 12-13-2006 10:43 PM
350 build up opinions? Artemis Entreri Engine 17 08-09-2006 02:48 PM
Build your own frame? Any basic thoughts? Madd Syntst Suspension - Brakes - Steering 9 11-28-2002 10:00 PM
